d15 to d16zc swap
Old Aug 27, 2010 | 05:57 AM
dmunoz's Avatar
Default d15 to d16zc swap
im looking around to see if my old d15 will swap with a d16 zc if so can anyone tell me what i need and if the ecu ar the same for both cars. im gettin two ecu with the motor i am buying so if anyone could help me let me know. also wil the distributor of my old motor fit the new one
Old Aug 27, 2010 | 05:58 AM
dmunoz's Avatar
Default Re: d15 to d16zc swap
and does any one knows if the ecu will fit
Old Aug 27, 2010 | 06:45 AM
~sp33~'s Avatar
EFB055
So you have an ED with a d15b2 (I'm assuming), and you want to swap in a D16a6 (or ZC? SOHC or DOHC?)
If you search using the full engine code you might find some helpful results.
Old Aug 27, 2010 | 07:21 AM
graveltravel2's Avatar
if you use your d15 intake manifold on the zc (assuming its the sohc zc non vtec) you will not have to change anything for it to run. and reuse the d15 distributor on the zc as well.
ecu's are different. d15 is 2 injector and zc of 4 injector...
look into dpfi tp mpfi swaps as well.
osmbr
33
Jan 15, 2010 05:10 PM
miguey310
May 16, 2009 01:28 AM
SinSeven
14
Jan 13, 2007 11:54 AM
janz3n
May 1, 2006 06:14 AM
contender
Jul 2, 2005 08:14 AM
