swap problems on SOHC VTEC ZC! please help!
hey all, i have a 94 vx hatch that i just swapped a SOHC ZC VTEC into. I used to be able to find the diagrams/instructions for converting a VX 7-wire to an SI 4-wire, but i cant now. I tried searching, but nothings popping up for me. ALSO, i'm getting a CEL for my MAP sensor and my TPS sensor. Anyone have any ideas? it's basically the same motor as the z6... just more power. I used the VX harness, any help is GREATLY appreciated.
Thanks for the quick response, however I was talking about the wires to swap off the harness for a 4 wire universal o2, not to use the vx o2. Also, the car redlines at about 5200 rpm, instead of 7200. Getting codes 1, 41 (o2 sensor), 5 and 7 (map and tps). I've switched the map and tps plugs, and it won't do anything without dying, so I know I've got the right plugs, replaced map sensor and same issue. Any ideas?
justseeingifitistaken
Aug 15, 2006 01:16 PM
SuicideSlide
Aug 24, 2005 10:13 AM
