Help with b16 tranny/clutch...can't change gears
Old Aug 26, 2010 | 06:36 PM
YungD618's Avatar
Default Help with b16 tranny/clutch...can't change gears
hi, i have a b18c1 motor with a b16 tranny and after driving all day, it didnt let me get into any gears at all. after letting it cool down for a little, it let me get into them for about 5-10 mins of driving but it made a soft winding noise and would act like i wasnt holding down on the clutch when i stopped in 1st gear (it stalled) then it stopped letting me get into te gears again. So any help would be appreciated
Old Aug 26, 2010 | 06:49 PM
ricky00's Avatar
Default Re: Help with b16 tranny...
is there any oil in the tranny
Old Aug 26, 2010 | 07:00 PM
YungD618's Avatar
yea, i just changed the fluid on saturday and put in 2.3qts
Old Aug 26, 2010 | 07:02 PM
ricky00's Avatar
did u install the clutch backwards?
Old Aug 26, 2010 | 07:14 PM
YungD618's Avatar
the clutch was in there when i bought it but i highly doubt its backwards b/c its driven fine for the past 2 months that i've had it. it started this outta nowhere
Old Aug 27, 2010 | 04:04 AM
94EG8's Avatar
Seagull Management
Can't be done on any honda i've ever seen. You can do it on some other stuff though.
Old Aug 27, 2010 | 06:02 AM
T Thrash 09's Avatar
this happened to me last night but on top ogf it when i finally got it into first i started drivin and the wheels locked up
Old Aug 27, 2010 | 06:19 AM
YungD618's Avatar
I'm thinking maybe it's b/c I drive it all day and I don't have a tranny cooler so maybe it got too hot or a clutch master or slave cylinder?
Old Aug 27, 2010 | 06:39 AM
idk my mine is doing the exact same thing so if you find out the problem post what you did
Old Aug 28, 2010 | 01:16 PM
YungD618's Avatar
welllll, i did even more research and found that people with same problem is b/c the pressure plate isn't tightened enough so it must've untightened itself so i just ordered a new clutch kit today and ill keep posted
Old Sep 13, 2010 | 11:20 AM
YungD618's Avatar
i haven't been on in a while, but it ended up being that 1 of the clutch disc springs popped off so it was jamming itself between the flywheel and vlutch disc, making it always engaged
Old Sep 13, 2010 | 11:47 AM
fv8s's Avatar
it sounds stupid but check your axles even though that is most likely not the issue. you mpost likely have an internal/ clutch problem
Old Sep 13, 2010 | 11:52 AM
8VEYBEYB's Avatar
check your master cylinder , clutch line , etc , sounds like you dont have any pressure in the system and are stuck in 1st gear or something.
Old Sep 13, 2010 | 11:58 AM
Civic_4life's Avatar
lol just to clear this up, honda 5 SPD tranny DO NOT have stock tranny cooler lol. only automatic do.
op i normally always do clutch check/change when i swap a tranny or replace it, hope u do same in future! had this happened couple times to my self also lol
Old Sep 14, 2010 | 09:40 AM
YungD618's Avatar
Default Re: Help with b16 tranny/clutch...can't change gears
^ yea i messed up on that post and didnt catch myself but it drives fine after i swapped clutches
lukasmccracken
Transmission & Drivetrain
Dec 30, 2013 08:29 AM
91EF919
Jun 2, 2011 08:12 PM
ls-vteccoupe
Oct 22, 2010 08:07 AM
YVERSION
May 3, 2007 01:56 PM
WhiteHonda
Jan 20, 2002 08:41 PM
