clutch is going out?
i got a stock d16z6 motor, and today i just realize that i've been letting the clutch out too high than usual. every time i launch, no traction loss. is that a clue that my clutch will very soon go out?
If your clutch were to be going out, you'd feel it slip first. And even then it'd take a long period of time from when it started to slip, to catastrophic failure.
Unless when you dump and all you feel is a quick grab followed by no moving and a high rev because you didn't expect it to slip and sit in place, I doubt your clutch is going, you just either don't have a lot of WHP or good traction.
EDIT: This is what I'm going off of.
Do you mean letting the clutch out at a higher RPM than usual
