TN FS\FT 96 prelude VTEC cover car (nashville)
NEW PRICE 10grand firm!, some bodys gonna get a hell of a deal. that much under the hood!!!!
ok so i guess this is gonna make it official, up for sale is my 96 bb1 heather mist met. prelude si vtec. i have had this car since 2001 all stock when i got it not one mod. flawless paint it had tan interior and just a stock h23a1, all mods were professional done and adult owned, it is a survivor car. never resprayedor taken apart it has benn well taken care of its whole life. it was on the cover of honda tuning april 07. i have changed a ton of stuff and made many upgrades since then. all parts were bought brand new. even the headlights were new in the box from honda. i have every receipt for every part and bolt over 40k, no joke. i have been toying with the idea of selling her for about a year. never thought i would, but with work, house, kids, wife and three other cars to take care of i just dont get to spend as much time with it anymore and i dont want it to just sit in the shop waiting for me to find time to enjoy it. i would rather some one with time to enjoy it have her. im asking 20k ish obo for it. or trade for something with a real book value of arounk 20k. with no or few mods. there is a nother shoot for a mag coming real soon. here is the mod list email mt23vtecbb2@gmail.com im on here or phone 519-1583 to check it out or questions about anything. i can do shipping if out of state. also see my photobucket for more pics http://s165.photobucket.com/home/mt23vtecbb2/index
the newest write up on the car. http://that-steez.com/2010/10/19/can-you-ccwhats-up/
the car is flawless runs hard, fast won lots of shows, the best parts and more time than i could ever think.
1996 honda prelude SI (BB2)
96 only heather mist met. origanal paint job
inside-
all black swapped interior
black suade headliner
memory fab carbon kevlar s58 seats
TDM low down sliders/ custom rails
sparco stering wheel & hub
razzo **** & pedles
autometer shift light (hidden in ac vent
tucked fuse box (pass air bag tray)
EL gauges
JDM climite Control
outside-
jdm black housing hedlights (new from honda)
jdm front bumper lights (96 only all clear)
jdm front bumper & light weight bumper suport
jdm rear bumper
accord rear lip (cut and sectioned)
Vis oem carbon hood
road race eng. carbon vent
sibon carbon front lip
painted side skirts
vision type MC carbon mirriors
BB6 glass sun roof
jdm tail lights
McCulloch bi Zenon H3 6000k HIDs (high and low beam)
rayburg h1 yellow, high beam swap
audio-
sony cd mp3 cdx660
vtec prelude amp
6x9 infinty sub in stock vtec location
infinty kappa 6.5 door
infinty kappa 6.5 rear deck
direct electronics 2 way keyless alarm with pager
ecu-
hondata p28 obd2 converted ecu (no jumper)
hondata s200
chassis-
k sport pro full coilovers
tanabe rear lower tie bar
tanabe front lower tie bar
tanabe rear upper tower brace
tanabe front upper tower brace
em racing c piller brace
brakes-
BB6 five lug swap
arp extended studs
abs delete
earls SS brake lines
vtec front calipers
front BB6 drilled and slotted brembo rotors
rear BB6 drilled and slotted brembo rotors
hawk pads front and rear
synthic dot 4 fluid
motor-
h23a1 block
88mm steel sleved
h23a1 crank, polished & knife edged
arp main studs
crower pro billit rods for h23a1
88mm je pistions 12:1 for h22a
je wrist pins & locks
wisco xe rings
h22a oem oil pump
h22a oem oil squarters
h22a oem water pump
h22a oem timming belt
h22a crank timming gear
h22a1 vtec head
full SFP port and polish
SFP 3 angle valve job and guides
rev titanim valves (stock size)
arp head studs
arp headder studs
skunk2 valve springs
skunk2 titunim retainers
skunk2 stage 2 cams
cometic head gasket
aem timming gears
h23a1 manual timming belt tentioner
place racing motor mounts
hondata heat shield
skunk2 pro intake manifold (port mached)
STR 70mm t body
aem fuel rail
aem presure regulator
acell 370cc fuel injectors
EGR delete
sparco oil cooler all AN -8 lines
-6 AN fuel lines
elderbrock -6 fuel filter
3" BB6 aem cold air intake
greddy catch can -8 AN lines
rs*r jdm 4/2/1 SS headder 2.5 outlet
rs*r exmag full cat back
car sound high flow cat
mugen low temp fan switch
mugen low temp thurmostat
mugen ver 2 oil cap
mugen rad cap
mugen covers
fal single pusher fan
koyo alu rad
samco sport rad hoses
forbidden motorsports cooling plate
SCI ignition box
MSD blaster ss coil
ngk-r wires
ngk-r iridum plugs
polished red typeS valve cover
custom tucked harness
trans-
MS24 BB6 trans
act presure plate
act clutch disk
clutchmasters alu fly wheel
custom hidden clutch line
wheels-
CCW classic race ver. 5x114.3 3piece wheels
16x8.5 +29 offset
mtech neo chrome lugs
225-45-zr16 yokohama es 100 tires
inside-
razzo **** & pedles
EL gauges
JDM climite Control
outside-
jdm rear bumper
Vis oem carbon hood
painted side skirts
BB6 glass sun roof
jdm tail lights
audio-
sony cd mp3 cdx660
vtec prelude amp
ecu-
hondata s200
chassis-
brakes-
BB6 five lug swap
arp extended studs
abs delete
vtec front calipers
synthic dot 4 fluid
motor-
h23a1 block
88mm steel sleved
arp main studs
wisco xe rings
h22a oem oil pump
h22a oem water pump
h22a1 vtec head
arp head studs
arp headder studs
skunk2 stage 2 cams
cometic head gasket
aem timming gears
hondata heat shield
STR 70mm t body
aem fuel rail
EGR delete
-6 AN fuel lines
mugen ver 2 oil cap
mugen rad cap
mugen covers
koyo alu rad
SCI ignition box
MSD blaster ss coil
ngk-r wires
ngk-r iridum plugs
trans-
MS24 BB6 trans
act presure plate
act clutch disk
wheels-
16x8.5 +29 offset
thanks, got a ton ofparts to go with her also. got some trade offers that arnt bad. but kinda looking for something newer and mostly stock. so it will be easyer to resale.
i posted her on mautofied and one kid calls and askes "how hard does the vtec hit" and "its turboed right" "can i just put one on?" i dont want them getting my car. some one on here that knows whats up needs to be the one to get her.
