Suspension & Brakes Theory, alignment, spring rates....
Rear Brake Disc Stuck
Old Aug 26, 2010 | 04:34 PM
SOHCunderdog's Avatar
Default Rear Brake Disc Stuck
Just a few weeks ago I wanted to take off my brake discs to get them resurfaced before I installed some fresh pads on my ITR. I got the screws out in the rears no prob, but when I tried taking off the disc it would not budge at all!!
What tricks have you guys tried to get the disc off if it is being stubborn?
Old Aug 26, 2010 | 06:37 PM
Drive 4 fun's Avatar
Default Re: Rear Brake Disc Stuck
I assume that you mean that the rotor is stuck to the hub. common if they have not been removed for a while. Whack with a rubber mallet, maybe more than once. they get a little corrosion. I do not resurface or change rotors when I change pads assuming that you have no problem but worn pads. Unless resurface is cheap, I would just replace the rotor if I was not going to use it as is.
Old Aug 26, 2010 | 06:43 PM
Thanks for reminding me of using a rubber mallet. will try that when I get back around to it.
My car is the 96 spec so finding the rear rotors are a bit challenging.
Old Aug 26, 2010 | 06:57 PM
I still would probably not resurface, unless you have a problem. Actually I never have, and go back and forth with track and street pads, including new sets when needed.
Old Aug 26, 2010 | 07:34 PM
roastbeefrichie's Avatar
"My car is the 96 spec so finding the rear rotors are a bit challenging."
fastbrakes.com has the 96 ITR 4X114.3 front rotors & rear rotors you're looking for:
96 SPEC ITR plain front rotor $100
http://www.Fastbrakes.com/product_p/...t%20rotors.htm
96 SPEC ITR plain rear rotor $80
http://www.Fastbrakes.com/product_p/...r%20rotors.htm
or
you can re-drill 94-01 integra 4X100 front & rear rotors to 4X114.3;
(which is cheaper to find & source off-the-shelf at any parts store)
the 4X100 94-01 integra & 4X114.3 96 ITR share the same sized rotors:
front rotor (10.3"/ 21mm)
rear rotor (9.4")
except their lug pattern is different
* for pads, since the 96 ITR 4X114.3 also shares the same calipers found in any 4X100 94-01 integra
(fronts stamped 17CL14VN & rears stamped 7CLP13S),
they also share the same sized pads
Old Aug 28, 2010 | 12:40 PM
Thanks for the links and info on the rotors richie.
cmyates007
18
Apr 14, 2012 10:19 PM
The Notorious Frosty
Nov 28, 2010 07:16 AM
Romo Pyro
Nov 15, 2010 05:31 PM
MachAF
Suspension & Brakes
Sep 26, 2009 10:02 AM
GSR18
Nov 9, 2004 07:58 PM
