The Del Sol Build That Seems To Never End!!!!!
Old Aug 26, 2010 | 04:28 PM
dickie691986's Avatar
Default The Del Sol Build That Seems To Never End!!!!!
I always wanted to build a decently fast Honda. I always fooled around with stock motors and really never had anything that pleased me yet this far. So once I got a couple dollars in front of me and a few people backing me this is what I came up with:
The motor: JDM B18C (GSR)
The car: '95 Honda Del Sol
The parts:
• Eagle Rods
• JE 81.5mm Pistons
• ACL Bearings (Standard mains/Race rods)
• Endyn Block Posts
• Endyn Catch Can
• Cosmetic 81.5mm Head Gasket
• NR1 Crank Pulley
• ARP Head Studs
• Skunk2 Pro Series Intake Manifold
• Hondata Intake Manifold Gasket
• Honda Prelude Intake Manifold Studs
• Precision 1200cc Injectors
• Walbro 255 Fuel Pump
• Blox Fuel Pressure Regulator
• B&M Fuel Pressure Gauge
• 12inch "Slimline" Radiator Fan
• Godspeed Dual Core Radiator
• Skunk2 Short Throw Shifter
• Skunk2 Shift ****
• Password JDM Shifter Bushings
• Skunk2 Pro-S Coilovers
• Blox Camber Kits Front and Rear
• Blox Rear Lower Control Arms (Brand new)
• Sunpro Gauges (Boost, Vacuum, Oil Pressure, volts)
• LC1 Wide Band With DB Gauge
• Electronical Boost Solenoid
• Nitrous Express Kit (for spraying the intercooler)
• Blox Oil Filter Adaptor
• Blox Vacuum Manifold
• Moroso Baffled Oil Pan
• Moroso Breather (for catch can)
• Skunk2 Cam Seal
• Type-R Throttle Cable
• Type-R Throttle Bracket
• 3inch Exhaust (straight pipe)
• ACT Xtreme Clutch Kit (AI4-XTG6)
• Fidanza Flywheel
• Skunk2 Titanium Retainers
• Skunk2 Dual Valve Springs (Tuner series)
The Turbo Set-up:
o AFI ram Horn turbo manifold
o Garrett GT35R turbocharger
o Tial mv-r wastegate (44mm)
o PeakBoost(Garrett core)24x6x3.5 Intercooler (2.5" inlet and outlet)(Bead rolled)
o Tial 50mm blow off valve
o (Aluminum)MANDREL BENT MIRROR POLISHED complete 3 piece 2.5" charge piping with bead rolled ends to prevent piping blow offs
o 3inch Stainless downpipe with stainless flex section
o Wastegate dumptube
o Stainless oil feed (-3) and oil drain (-10) lines
o Weldless 100% leak free oil drain line
o Strong T-Bolt hose clamps
On this set-up the car made 470whp and 315tq. I maxed out the air flow of the inner cooler and the intake manifold with this set-up. I do plan on more power to come as soon as I can come up with the money to do so....
The Car Was TUNED BY Innovative Motor Works & J-K Tuning Out Of Carlisle,Pa
Old Aug 26, 2010 | 04:29 PM
Default Re: The Del Sol Build That Seems To Never End!!!!!
Pictures of the build to follow soon........
Old Aug 26, 2010 | 10:57 PM
Professor_X's Avatar
yes, pics please!
Old Aug 26, 2010 | 10:59 PM
DAN!!!'s Avatar
how much cash did you have to drop into that GSR? def. need some good pics
Old Aug 27, 2010 | 11:24 AM
I will be posting a few of the pictures from my build here in a couple of hours.
Old Aug 27, 2010 | 11:26 AM
Not 100% sure on the exact dollar amount, but im sure with everything all said and done to the car including some jdm parts that I have not listed its over $15,000.
Old Aug 27, 2010 | 07:31 PM
Here are a few pictures of the car with the bone stock gsr in it for now.
Old Aug 27, 2010 | 08:35 PM
DAN!!!'s Avatar
thats dope, its a total sleeper. needs some rims though, maybe a set of GSR blades to match the motor??
Old Aug 27, 2010 | 09:25 PM
team_ibR's Avatar
so Im guessing you have not bought any of the parts listed yet.
Old Aug 28, 2010 | 02:12 AM
Iv thought about getting a set of blades for it but im starting to like the cheap shitty looking ****. lol
Old Aug 28, 2010 | 02:14 AM
No the parts are bought and I drive the car daily. Thats why I posted the dyno sheet. Im doing this post just a little backwards from the way everyone is use to seeing a build thread done.....
Old Aug 28, 2010 | 11:20 AM
Picture Time!!!!!!!
we will make this short and sweet to get right to the better pictures sooner:
More to come later.....
Old Aug 28, 2010 | 11:27 AM
MidShipCivic's Avatar
Cheap *** gasket, lose it, will leak on you sooner or later.
Old Aug 28, 2010 | 04:12 PM
I havent had a problem with it yet and have been using it for about 7 months or so. I am getting ready to do some other work to the car and I might just put a new one on.
Old Aug 28, 2010 | 06:45 PM
Some random motor tare down picture:
Old Aug 28, 2010 | 07:07 PM
Get rid of that gasket it's commonly those cheap ones you find included on ebay chinese sellers headers.
There is always someone who somehow never happens to have a problem....
Middle is Honda header gasket save yourself the headache never use one of those again.
Old Aug 29, 2010 | 08:23 PM
While waiting on the motor to get back from the machine shop I mounted up my inner cooler. I will start posting up the rest of the pictures from my build tomorrow. Please let me know what you think this far.
Old Aug 29, 2010 | 08:24 PM
What Exhaust gasket do you recommend then?
Old Aug 29, 2010 | 08:34 PM
I also use various company that make copper gaskets they conform to surfaces verywell, important when you're turbocharging since more heat is generated.
SCE makes a good one it's embossed with a lip around the port, lasted 3 years cleaned it off bolted it back up.
SCE site.
http://www.scegaskets.com/SCE-Pro-Co...30181-1-2.html
Cheapest place I know.
http://www.autopartsdealer.com/sce_p...ntent=APD63515
Old Aug 29, 2010 | 08:40 PM
shietzitzkien's Avatar
holy sleeper
Old Aug 29, 2010 | 09:53 PM
iamthefollower's Avatar
Very nice, I miss my Sol .
Old Aug 30, 2010 | 10:39 AM
Thanks to everyone who have left comments and that have looked at my page. please keep the comments coming. I will be posting more pictures of the actual build at some point today....
Old Aug 30, 2010 | 09:01 PM
cruizinmax's Avatar
intercooler. Sorry. lol
Old Aug 31, 2010 | 07:07 AM
Soooo as of yesterday my motor decided to let go on me and theirs no saving it . However I will continue to post pictures of the build up. Just to follow with pictures of all the damange that happened when the motor blew......
Old Sep 9, 2010 | 03:30 PM
So Since I blew the motor up here is the first picture of the damage that I took....
