Transmission & Drivetrain Gearboxes, Differentials, Clutches
k20 tranny problem...please help
Old Aug 26, 2010 | 01:04 PM
jdm_obsession88's Avatar
Default k20 tranny problem...please help
I have a 96 hatch with a k20a2 swap. When im sitting still it goes into all 6 gears perfectly. But when im driving it wont go into 6th at all and 5th seems a little crunchy at times. Why is that? Is it a clutch or tranny problem or syncros? thanks
Old Aug 26, 2010 | 02:07 PM
Honda Bull's Avatar
Default Re: k20 tranny problem...please help
Possible 5-6 synchro sleeve damage.
Possible 5th and 6th gear damage.
Possible shifter assembly malfunction.
Old Aug 26, 2010 | 02:25 PM
Well it went in soon after the swap and then it slowly got worse and now wont go in at all according to the previous owner. Should I just replace the tranny or what?
Old Aug 30, 2010 | 09:58 PM
So Cal Egee's Avatar
I just have the same problem my mechanic looked at the shifter box , the cables checked the clutch slave and master cylinder. after that he took the tranny out it ended the clutch disk had a piece boken (a part that held one of the little springs) that was loddged in the pressure plate. I would take a look at the clutch, but first check your clutch master cylinder and slave for any leaks good luck.
Old Aug 31, 2010 | 03:56 AM
Ok bro, will do, thanks for the help.
JDM_LS
Jun 21, 2008 09:05 PM
ek_b16
Dec 10, 2006 10:19 PM
ajrees25
10
Oct 10, 2005 04:31 PM
sloaccord
Mar 23, 2005 10:31 PM
Intercooled JRSC
Oct 16, 2004 11:42 AM
