93 Eg si hatch Speedo acting crazy
Old Aug 25, 2010 | 09:19 PM
93grayeg's Avatar
Default 93 Eg si hatch Speedo acting crazy
I got a 93 eg si hatch and I just fixed the cluster lights in it ( bad dimmer switch ) Anyways Now every now and then my speedo will just go crazy , go from 40- 100mph out of no where, sometimes it even goes backwards , then it will just all of the sudden go back to the right speed. . Any ideas? Never had this issue before. Thanks
93grayeg's Avatar
Default Re: 93 Eg si hatch Speedo acting crazy
btw it is the stock eg si cluster
Old Aug 25, 2010 | 09:21 PM
D16SiHatch's Avatar
in my case the speedo circuitry took a **** on me and i had to replace the cluster to fix it. do you have cruise control by chance, and if so does it still work even when the speedo is reading incorrectly? just kinda have to find ways to narrow it down to either the cluster or the speed sensor itself.
Old Aug 25, 2010 | 10:06 PM
93grayeg's Avatar
no cruise control, car has a full gsr swap
Old Aug 25, 2010 | 10:08 PM
ricky00's Avatar
did it just happen? was it working before u fix the light?
Old Aug 25, 2010 | 10:16 PM
hondawhiz's Avatar
i think the cluster is messed up. try tapping it while it starts doing the thing, and if not, then the speed sensor.
Old Aug 25, 2010 | 11:00 PM
93grayeg's Avatar
Yes it was working fine before.
I did try tapping it, Didnt make a difference
Old Aug 25, 2010 | 11:01 PM
hondawhiz's Avatar
speed sensor failure. jack it at the junk yard. from any single cam or dohc. just not h series.
Old Aug 26, 2010 | 08:20 AM
93grayeg's Avatar
Okay so Sohc will work on the gsr?
Old Aug 26, 2010 | 08:25 AM
hondawhiz's Avatar
yeah.
Old Aug 26, 2010 | 08:29 AM
ludesrv's Avatar
I had the same problem. Turned out the pin in the plug for the cluster was spreading open. Check the condition of your connector. One poor connection will cause the same symptoms. I too replaced my VSS and cluster before I noticed the damaged pin. I just cut and soldered a newer, cleaner plug onto the harness.
Old Aug 26, 2010 | 09:22 AM
93grayeg's Avatar
okay thanks man , ill check that first. Is there any way to just clean the connections ?
Old Aug 26, 2010 | 11:38 AM
CivicSi95's Avatar
my speedometer is doing the same thing. i was told the replace the speed sensor as well and it did not fix the issue.
Old Aug 26, 2010 | 12:41 PM
hondawhiz's Avatar
cluster could be bad. common problem
Old Aug 26, 2010 | 12:48 PM
Bartman201's Avatar
I had the same issue I removed the VSS and clean the conectors that fix my problem.
Old Aug 26, 2010 | 09:00 PM
93grayeg's Avatar
okay guys , I tried tapping on the cluster a little harder today when it started acting up and it started working, so tapping does stop the problem for a little. . then it acts back up again
Old Aug 27, 2010 | 02:16 AM
Love-MY-honda's Avatar
i have the same prob. on my ek. my rpm and speed dont work at all. its been like this for a while. everything else works and no engine check. could it be a cluster gone wrong?
Old Aug 27, 2010 | 07:04 AM
hondawhiz's Avatar
then its the cluster for sure.....
Old Aug 27, 2010 | 08:24 AM
ok sweet thanks for the affirm. on that.
Old Aug 27, 2010 | 08:37 AM
ludesrv's Avatar
In EKs its common for the cluster to wear out (Mine did, and all the junkyard cluster all have the speedo assembly missing from them!). But I have clusters from EGs with over 500XXXkms and they never skipped a beat. Never heard of dead cluster issues in EGs but anything is possible.
Old Aug 27, 2010 | 08:42 AM
94EG8's Avatar
Seagull Management
They do go bad periodically, I went through 3 before a I got a good one in my '93 Si.
Old Aug 27, 2010 | 08:45 AM
Jimster480's Avatar
its probably not the speed sensor. I had the same problem on my 97 coupe and it turned out that the fuse for the speedo/alternator was messed up and dieing. Sometimes my speedo would work other times it wouldnt, other times it would randomly jump around (sometimes when I was even sitting still). It turned out to be a fuse. And I think that fuse blew because my alternator regulator died aswell. So I think the alternator caused the whole problem, so check your alternator, and your speedo fuse before replacing the speed sensor.
Old Aug 27, 2010 | 11:06 AM
94EG8's Avatar
Seagull Management
'92 - '95 civics never really had any issues that way. '96 - '99 Civics ('00 models aren't supposed to be affected) had issues with the engine harness rubbing the bracket under the intake manifold and shorting out the signal wire for the VSS among other things usually blows the alternator fuse and the speedometer just flys all over the place, dash lights pulse etc.
Old Aug 27, 2010 | 12:12 PM
also would a a/t cluster work on a m/t?
Old Aug 27, 2010 | 12:40 PM
94EG8's Avatar
Seagull Management
Yes, it will of course have the PRNDL indicator though.
