Braided Brake Lines: Difference between ABS & non-ABS for 92-95 Civic Si Hatch?
I've got a chance to pick up some little-used but second-hand stainless Goodridge braided lines for a 92-95 Civic Si Hatchback. The price is right and I'd like to jump on it ... save that it's likely the lines came from a Civic Si that had ABS. My vehicle does not.
I see that the part numbers are different for the Goodridge kits for ABS vs. non-ABS. I looked up the Civic parts diagrams and indeed the OEM front brake lines (from hard line to disc) are different part numbers on the one with ABS vs the one without. See here: NON-ABS is #27 & 28 vs. ABS is #25 & 26
Wondering if anyone knows what this actual difference IS, and whether the stainless lines will still work PROPERLY for my non-ABS brakes.
Thanks...
Thanks...
You should be alright. It's probably just the length of the brake line that is a little different to allow for the abs sensors.
I am suspecting as much. I wonder if anyone out there has had the chance to compare?
darkstormcr
Nov 7, 2011 10:36 PM
BLKTeg94
May 14, 2006 09:18 AM
EL-Driver
Feb 5, 2002 05:18 PM
