Help with jdm h22a into 99 prelude
i had found a page a while ago that showed exactly what needed to be swapped over to make the swap work but that link is dead
so does anybody have the list of what i need to use from my h22a4 to swap over to the jdm h22a to make it work properly in my 99 prelude
thanks for any help
thanks for any help
You can just ask the people your ordering a motor from to give you a OBD2 H22a, then all you'd have to do is switch the fuel rail and that's it unless you want the OBD1 motor.
Swap the oil pump from the obd2 engine over, and for good measure, might as well do the distributor and knock sensor at the same time. Other than that, make sure everything is in the right spot for the wiring harness.
allmotorC5
Jun 23, 2001 06:45 PM
