secondary o2 sensor wire
ok, well i found the problem for blowing my alt fuse, secondary o2 sensor, ok well i cut out the junk part of the wiring, now my quiestion is there are 4 wires 2 blk, 1 whi, 1 grn, are the 2 black both grounds, im not sure witch goes to witch or if it doesnt matter, i forgot to mark wen i cut apart...but they are both grounds arent they?
The black wire that changes to a blk/yel wire after the connector is the power wire.
The black wire that changes to a blk/wht wire after the connector is the one that grounds on the ECU.
bmxtrev
Jun 28, 2012 09:17 PM
elmalouno
11
Aug 18, 2004 09:06 AM
