S2000 INTEGRA and RSX parts, Plainfield IL
Please EMAIL or TEXT me.
I do accept trades
EMAIL DanRiversJr@gmail.com <<<<also my paypal address
TEXT 630-957-8798
Hello, my name is Dan
I'm located in Plainfield , IL
TEXT 630-957-8798
S2000 parts
Injen cold air intake - $120
4IGs cold air intake - $120
JPM Coachworks shifter boot, center carpet, and elbow pad cover....all new, black alcantara with Red stitching - $200
JDM Integra stuff
JDM DC2 bumper, garnish, lip, CF fenders, rear bumper, pair of OEM JDM HID headlights, pair of OEM JDM non-HID headlights, driver side OEM JDM non-HID headlight - $1800 obo for all
JDM ITR gauge cluster - $130
Autometer dual pod gauge bezel - $50
RSX Type S stuff
DC5 type S gauge cluster (45k miles) - $130
DC5 Vision CF intake manifold cover - $100
OEM type S valve cover - $100
Megan under body brace - $50
Ingalls torque dampener new - $110
Prelude stuff
Floormats
I also have an OEM honda tape deck cleaning kit.
OEM S2000 PARTS -
brake master cylinder 07 16k miles $60 shipped
clutch master cylinder 07 16k miles $60 shipped
fuel sending unit 07 16k miles $75 shipped
Hubs $90 each shipped
Control arms $75 each shipped
spare tire $60 shipped
clutch slave cylinder 07 16k miles $50 shipped
long block 07 16k miles $2500 shipped
vtec solinoid 07 16k miles $60 shipped
crank pulley 07 16k miles $55 shipped
injectors 07 16k miles $140 shipped
alternator 07 16k miles $70 shipped
a/c compressor 07 16k miles $70 shipped
Rear sub frame 07 16k miles $220 picked up
drive shaft 07 16k miles $225 shipped
drive shaft 01 30k miles $200 shipped
drive shaft 01 46k miles $180 shipped
ABS sensors $45 each shipped
oil pressure sensor 01 46k miles $35 shipped
Idle air controller 01 46k miles $35 shipped
Start button 01 46k $40 shipped
Hazard button 01 46k miles $20 shipped
passenger window switch 01 46k $25 shipped
O2 sensor 07 16k miles $45 shipped
Catalytic convertor 07 16k miles $140 shipped
RL AP2 shock’07 16K- $60
RR AP2 shock ’07 16K- $60
FL AP2 shock ’07 16K- $60
RR AP2 Shock ’05 900miles-$75
RL AP2 Shock ’05 900miles-$75
Water pump AP2 ’07 16k-$60 shipped
Starter AP2 ’07 16k - $60 shipped
Motor Mount Brackets AP2 ‘07-$35 shipped
Serpentine Belt tensioner AP2 ’07 16k- $55 shipped
Fuel Rail with pressure regulator AP2 ’07 16k- $45 shipped
AP1 flywheel - $90 shipped
rear brake discs $25 each shipped
brake pads front or rear set $25 shipped
heater control valve with bracket - $35 shipped
EPS module $40 shipped
brake master cylinder ap1 - $60 shipped
brake distribution valve ap1 $35 shipped
ABS modulator AP1 $75 shipped
Trunk release module $40 shipped
AP1 header $85 shipped
Gas pedal assembly $35 shipped
Coolant reservoir $25 shipped
AP1 rims full set $285 shipped
Passenger a pillar cover $25 shipped
Spare tire cover trim - $30 shipped
Door sill trim - $30 each or $45 both shipped
Lining, lower cowl side - $25 each or $40 shipped both
Rear garnish - $30 each or $45 shipped both
AP1 console cover $65 shipped
AP2 console cover $240 shipped
Brake Calipers - $50 shipped each
Timing chain tensioner $60 shipped
Under hood fuse box AP1 $120 shipped
Seats 07' 16k miles - $800 shipped
drivers headlight with broken tab $170 shipped
cluster with plugs $240 shipped
Radio with code card $100 shipped
Speakers $45 shipped
passenger air bag $250 shipped
I do accept trades
TEXT 630-957-8798
TEXT 630-957-8798
S2000 parts
JDM Integra stuff
RSX Type S stuff
Prelude stuff
Floormats
OEM S2000 PARTS -
JDM_MOB
Sep 8, 2013 08:42 PM
Sleepercivic2
May 16, 2012 03:02 PM
