Base Oil Pan vs. Type S Oil pan...
Steel is flimsy? Really? To the o/p, The base a3 and the type s share the same oil pump, so both pans are interchangeable. If you run the steel a3 pan, make sure you get the flywheel cover to go along with it.
the a3 civc motor has shafts the a3 rsx motor uses the same pump as the type s.. do not get that confused, or the pans confused. that's why i said match the pan to the pump not the motor
A3 and A2 from RSX share the same oil pump. I have both bottom ends in my garage and they are the same. You can verify below.
A3
http://acuraautomotiveparts.org/acur...s=&view=normal
A2
A3
A2
yeah we already know that,,
here is the a3 civic si motor for reference
http://www.hondapartscheap.com/south...NER&vinsrch=no
