need help i think my car is dead :''(
Old Aug 25, 2010 | 01:15 AM
Baten619's Avatar
Default need help i think my car is dead :''(
so i put in a new slave cylinder for my 90 accord and i just cant get the cluck to work i push down and it wont come up so i do it by hand you know up down up down so on it just won go i bleed the line and ever thing idk i think it dead
Old Aug 25, 2010 | 05:09 AM
ilikehonda's Avatar
Default Re: need help i think my car is dead :''(
check to see if you master cylinder is leaking
Old Aug 25, 2010 | 07:04 AM
Baten619's Avatar
thats not leaking so you think it must be a leak some place? i look and i dont see any do i have to fill the master cylinder to the top and put the cap back on for it to work or just to the max line?
Old Aug 25, 2010 | 07:34 AM
Baten619's Avatar
sry also my cluch hits the floor i was drining when it just did that so my body look at it and the slave cylinder was all busted up one of the holes for the 12mm bolt was no more and a **** where the other 12mm bolt on the slave was just gone so i have to run it with one bolt i have it alined so idk if thats why its not working bcz am running with one bolt?
Old Aug 25, 2010 | 07:56 AM
d16y8turbo's Avatar
If the slave cylinder isn't moving when you depress the clutch that isn't the problem. How did you go about bleeding the system?
Old Aug 25, 2010 | 08:03 AM
Baten619's Avatar
well i had to do it along so that sux but i open that bleed valve and i then push down slowly on the cluch and then look at the master filled it up and then push again ect. did that good like 30 or 20 mins or so
Old Aug 25, 2010 | 08:34 AM
alvarado626's Avatar
gravity bleed just open the bleed valve let the fluid run out make sure u have enough fluid don't let it go empty do not move the pedal just let it run by it self
that's how i did mine i did that twice and it work just fine then go back and do it with the pedal
Old Aug 25, 2010 | 08:35 AM
Baten619's Avatar
ok i got a buddy just now he dedal and i watch it but ill do that now ty ever one i really need this car for work
Old Aug 25, 2010 | 08:36 AM
If ur in The L.A. Area I Can Drive down and Help u Out
Old Aug 25, 2010 | 08:52 AM
Baten619's Avatar
TY TY TY alvarado629 tht work but bcz am running it with one bolt i have no chose its miss alined ill **** with that to try to get it to work. am in lame a$$ Lincoln, Nebraska i was from L.A but fam move up here also i had no chose TY again
Old Aug 25, 2010 | 01:46 PM
ilikehonda's Avatar
The system will not just gravity bleed. You need someone to actually open and close the bleed valve. Everytime you pull the pedal up you are sucking air back in to the system.
Old Aug 25, 2010 | 06:27 PM
d16y8turbo's Avatar
I agree. Make sure you're bleeding the system properly.
Old Aug 25, 2010 | 07:02 PM
bseriescrxsi's Avatar
and running it with just one bolt wont work....guy who i bought my car off of tried that...needless to says the car required a new clutch and slave cylinder when i got it
Old Aug 25, 2010 | 07:48 PM
HonBeer's Avatar
DUDE! Come on....Its so hard to read that second grade grammar. Stick a period or two in that sentence so it will be easier to read.
Old Aug 26, 2010 | 08:10 AM
Baten619's Avatar
ya i think i need a new transmission bcz thats were the slave cylinder bolts on to right? bcz one of the holes is gone like the top part just broke off idk how.
Old Aug 26, 2010 | 10:02 AM
ilikehonda's Avatar
pics. Have you tried an easy out? It will get the broken bolt out then you can go to the auto part store nearest you and get a new bolt. If that doesnt work then you can drill it out and rethread the hole.
Old Aug 29, 2010 | 08:13 AM
Baten619's Avatar
ok this are the pics and shows you what is broken.
Old Aug 29, 2010 | 09:13 AM
HonBeer's Avatar
Hey Gomar! Learn how to crop your pics. You must be a genius!
Old Aug 29, 2010 | 10:14 AM
Baten619's Avatar
your mom is a genius. am asking for help dude so why you even here if your not here to help
Old Aug 29, 2010 | 11:51 AM
JB3BELL331's Avatar
sry man. had the same prob w/my 94. i had the slave cyl & master cyl replaced. wrked fine after that
Old Aug 29, 2010 | 01:06 PM
photo cropped and labeled as it should be for easy reference.....to the OP you should still be able to thread a bolt far enough into that hole
Old Aug 29, 2010 | 05:42 PM
Baten619's Avatar
ok ty ill try that
Old Aug 30, 2010 | 09:08 AM
Baten619's Avatar
ya dude not working really it like trys to get in but just short of it like maybe 2 1/2 turns in and just comes out. ill keep trying but what is that part that it bolts on too? can i take it to a shop and have it replace ?
Old Aug 30, 2010 | 10:40 PM
holmesnmanny's Avatar
I bet your only problem, assuming you installed it correctly originally, was that you had air in the system. You weren't bleeding it correctly. When you get air in there, there is nothing to press back on the pedal and it just sticks down. Sorry to hear about the extra problems.
Old Aug 30, 2010 | 11:05 PM
if you read he did look at the slave and it was engaging the fork...if the slave moves there shouldn't be air in the system...air will cause it to not move at all
