check engine light on steady
Old Sep 17, 2002 | 04:21 PM
mkokwilson's Avatar
Default check engine light on steady
I was told my check engine light was on cuz I didnt crank the cap on enough, can I reset this myself?
Old Sep 17, 2002 | 07:53 PM
XKWISIT1's Avatar
Default Re: check engine light on steady (mkokwilson)
you can try disconnecting the battery. If that doesn't work,then you will have to hook up a scan tool to remove the code.
Old Sep 17, 2002 | 07:57 PM
B00ST2nR's Avatar
try jumping the wire to recieve the code. It tells you what the problem is and you can go from there...
_uh_oh_
Honda Civic (2001 - 2005)
Mar 31, 2008 04:07 PM
importdude2000
Jul 17, 2004 12:53 PM
laurat
Oct 14, 2002 12:54 PM
mkokwilson
Sep 17, 2002 04:22 PM
