my radiator is losing coolant and dont know where to help!
Old Aug 24, 2010 | 09:59 PM
Kgill23's Avatar
Icon6 my radiator is losing coolant and dont know where to help!
Hey i have a 89 accord lxi. I have to fill my radiator up every three or four days no leaks under my car at all. no leaks from the heater core. and no coolant in the oil. I took it to a mechanic and he said it would probably be the head gasket after awhile but it was fine for now. i have had a puff of white smoke one time in the morning so i am thinking of buying some of that head gasket sealer but im not sure how that stuff works but i dont think the gasket would be too bad right now after what the mechanic said so im hoping it will fill the little crack or whatever that is therre. My car is running very good still no loss of power i drive it everyday it only overheats when the raidiator is low which is when i forget to check lol but right when i get coolant in it the temp goes right back down. please let me know what u guys think thanks!!
Old Aug 24, 2010 | 10:06 PM
E-Rok's Avatar
EPIC TUNING
Default Re: my radiator is losing coolant and dont know where to help!
check coolant hoses. My integra had a pinhole leak on a small hose on the head (forgot which one) and it would just steam out of that and run empty eventually. did a pressure test and found it.
Old Aug 24, 2010 | 10:15 PM
slomofo's Avatar
GDD Member
Why didn't your mechanic pressure test the system? If he pressure tests it and finds no leaks, change your radiator cap and see if the problem still occurs. (pressure test can't test cap).
Old Aug 24, 2010 | 10:50 PM
tazeat's Avatar
Check your cooling system.
Old Aug 24, 2010 | 10:58 PM
philafelman's Avatar
pressure test...
/thread.
Old Aug 24, 2010 | 11:12 PM
Malfa's Avatar
well, you're definitely in the right place
Old Aug 24, 2010 | 11:25 PM
Maverick's Avatar
Team Purple
Looks like GDD is on vacation.
Old Aug 25, 2010 | 03:55 AM
Mrs 5th's Avatar
Its probably just putting fires out under the hood
Old Aug 25, 2010 | 04:30 AM
KYSI's Avatar
Nil Desperandum
On an episode of Macgyver he used some eggs to stop a leak.
Old Aug 25, 2010 | 10:28 AM
Kgill23's Avatar
im gonna do the pressure test thanks..
Old Aug 25, 2010 | 04:19 PM
Grnnt4's Avatar
Holy crap, I forgot all about that episode. Classic!!
Old Aug 25, 2010 | 06:14 PM
Canuck99's Avatar
I have seen many head gasket leaks on those...A slow leak at the water pump weep hole may be a source of a leak when engine is cold and a pressure test may not pick up small leaks. Pull the plugs and look for a white one(insulator tip white and not tan or dark), white smoke is a possible indication of coolant in that cylinder but will sometimes cause a missfire when first started...just some ideas. Sometimes debris in the cooling system will plug the leak it self temporaraly...engine head stop leak is again, a temp fix.
Old Aug 25, 2010 | 08:10 PM
Kgill23's Avatar
so do u think i should do the compression test yet or not? and why look at the white spark plug? and what do i look for?
Old Aug 27, 2010 | 08:52 PM
Canuck99's Avatar
The insulator tip of the spark plug will be white and thats the hole thats burning coolant....
If you do a pressure test leave it under pressure for a while even overnight it may allow the coolant to be pushed into the cylinder even if its a small leak...
Compression test won't tell you anything much, you said it runs fine and has lots of power meaning the actual compression is ok.
Old Aug 29, 2010 | 06:37 AM
burnitdown's Avatar
auto? if so you may be losing it through the tranny cooler
Old Aug 29, 2010 | 06:46 PM
Kgill23's Avatar
Ya its a automatic. and how can u check if its leaking into the tranny cooler?
Old Aug 30, 2010 | 03:14 AM
Canuck99's Avatar
LOL beat me to it...either you will see milky looking transmission fluid in you trans or transmission fluid in your rad or overflow, its quite obvious too. Hope not though.
GeneEllis
Aug 29, 2013 06:06 AM
thewrai6th
Feb 8, 2013 02:11 PM
xpdude
28
May 3, 2010 02:33 PM
SoCalHatch
Jul 19, 2009 05:42 AM
A Tribe Called Honda
Feb 21, 2008 03:19 PM
