B20 SWAP QUESTIONS
Swapn out the b18a1 wit an b20b almost done but have a few questions still.
Do i use the pr4 ecu or do i need another one? I was told i could still run it..
I have an obd1 mani but an obd0 throttle body. Can i block of the FICV hose?
Last theres an engine temp sensor on the b18 an not the b20. Leave it hangen or wat?
Thanks in advance
Thanks in advance
The Pr4 would still run it no problems ls and b20 are no different just internls so your fine there.As 4 your manifold jus use the old manifold from the ls and keep the throttle body(obd0)
I need help myself on a b20b swap myself.Car has no fuel on spark plugs no smell anything.Car tries to crank but no spark comin out of spark cables either.Do you or anyone think its my dizzy(obd0 dizzy) or maybe my injectors are not wired correctly.I still am using the obd0 injectors from my old harness.They were just cut and splice from other injector harness to make longer
Nameless RB26
14
Jul 29, 2009 06:10 PM
