cheap ebay adjustable cam gears
Old Aug 24, 2010 | 07:47 PM
raverx3m's Avatar
Default cheap ebay adjustable cam gears
was looking for cam gears and saw these
http://cgi.ebay.com/ebaymotors/97-01...ts_Accessories
not sure if anyone tried them yet or how long they been on ebay, seems like a freshly baked knockoff.
wonder hows the quality lol
damn lol i guess theres a whole family of ebay cam gears already
Old Aug 24, 2010 | 07:53 PM
cloviskilla's Avatar
Default Re: cheap ebay adjustable cam gears
go golden eagle. those ebays arent accuratte for ****.
Old Aug 24, 2010 | 09:37 PM
raverx3m's Avatar
golden eagle are expensive
i m aiming at 130-140 range thats all i got to spend on cam gears.
Old Aug 25, 2010 | 11:18 AM
xtremescouts's Avatar
well not to be a dick but if you cant afford nice ones just rock your stockers and keep saving until you can. youll regret buying the cheapies. I had a set that was pretty similar to what you have up there in the picture about 5 years ago and they were garbage. First the bolts stripped where you put the allen head in(i wasnt tightening all that hard, just shitty bolts) and then after a couple months they would start changing theyre settings a little at a time. I would double check how tight they were all the time and it was always tight but they kept changing around.
I have heard other horror stories as well as the ever so common accuracy issue as well. With as cheaply as they are made there is no way that they got them right.
just my two cents tho. If you just want the look of cam gears then you can buy them but id atleat put different bolts in them and tighten them up really tight and check pretty often.
Old Aug 25, 2010 | 11:32 PM
chewyv's Avatar
pm4nudes
jump jump skip skip chip chip
Old Aug 26, 2010 | 08:11 PM
uberEFtuner's Avatar
Never buy critical parts from ebay. Unless you like cheap stuff breaking.
Old Aug 27, 2010 | 08:29 AM
92civlude's Avatar
Youre going to notice the TDC marks will be off. Compare them to the Honda pulleys and use a hacksawblade to scribe accurate TDC marks. If you will tend to adjust your cam timing more than once, youre going to gall up the pulley where the lock bolts tighten down. It will get to the point where you will be unable to adjust them. So if you do adjust. do it one time and lock those bolts down with locktite.
Old Aug 29, 2010 | 11:28 AM
crxturbo177's Avatar
are the skunk2 cam gears any gd? any one with any experience with them?
Old Aug 29, 2010 | 11:53 AM
raverx3m's Avatar
93b20z
Sep 3, 2007 12:05 PM
InvaderTrax
May 29, 2006 05:13 AM
ka-nife_
Jul 22, 2005 06:27 AM
rough_draft
May 17, 2004 05:19 AM
