Classic Hondas All Pre-1988 Hondas.
87 crx suspension info
Old Aug 24, 2010 | 06:26 PM
OCdude31990's Avatar
Default 87 crx suspension info
i want to lower my 87 crx but as you guys know there arent too many aftermarket parts for this car. will another generation civic's suspension work( maybe the 88-91 civic)????
Old Aug 25, 2010 | 04:18 AM
E-AT_me's Avatar
Default Re: 87 crx suspension info
nope. the only other parts that will work are parts from an 86-89 integra, which are the same as the civic, and rear shocks for an integra type r have been known to work.
lowering the front is pretty easy. all you have to do is turn the t-bar adjusters and you're fine. you'll run out of shock travel quickly though unless you do something to shorten the shock shafts. upgrademotoring has stiffer torsien bars. you'd probably want 24mm for the street.
shocks are available. heel toe auto may still have a set of teins midevil pros available, but they are expensive. koni discontinued shocks. tokico should still be available along with KYB
springs are plenty available from tokico, ground control and the like.
Old Aug 26, 2010 | 09:05 AM
cbstd's Avatar
Come on over to www.redpepperracing.com for more information about the 1st Gen CRX and its 3rd Gen Civic brother.
Also check out the www.japaneseclassiccarshow.com on Sunday September 12, lots of Redpepper members will be showing their CRXs there.
Scott
Old Aug 28, 2010 | 09:20 AM
staticchmbr's Avatar
^^these are the only ways to do it without being halfassed too. also, if you lower the back with coilovers or springs (if you can find them), you might want to get an adjustable panhard bar to keep the rear axle straight.
Old Aug 31, 2010 | 09:40 PM
NW Classic Honda's Avatar
External sway bars are one of the best upgrades on these cars.
Old Sep 8, 2010 | 08:33 PM
Monster3000's Avatar
Just got my first CRX its a 87 si and from what iv looked threw for the rear and still best money reasonable way to go is get the rear coil over sleeves from Ground control i just ordered a set for mine
Old Sep 9, 2010 | 09:59 AM
Spunkster's Avatar
Besides a B-series swap, the Teins are the best modification you can do to one of these cars.
I personally run an 88 Integra with a turbo charged B18C5 and the Teins...as well as other goodies. I'll be at JCCS agin this year....my 87 Teg was totalled when i was hit by a drunk driver running from the cops back in Feb., but I was able to swap everythign to a new chassis.
Old Sep 10, 2010 | 05:48 AM
cbstd's Avatar
I'll be there with my red '87 CRX Si, see you there.
Scott
jdmrexx
Nov 8, 2008 05:46 PM
supracrx
Feb 17, 2006 10:46 PM
bad_azz_bmr
Aug 26, 2004 10:19 AM
TheBlackCrx
Oct 31, 2003 09:31 AM
vg30dett71510
Jan 6, 2003 04:13 AM
