94-97 accord h22-h23 swaps
sup people i got a 96 accord wagon with a 2001 h23a vtec. i had a idle problem so i changed the throttle body and put the one from the accord,now can any body tell me if the us prelude throttle body is as big as the accord one?
The Accord TB is much much smaller. You're restricting yourself now.
yea i know but the tb that the engine brought was not working with the tps that i have so i replaced it with the accord's for the mean time but thanks for giving me info on the size,it realy helps.oh and one more thing, were can i get the ignition cap for this engine and the intake manifold gasket,the h22 gasket don't match onless i put a usdm manifold.
i had changed the intake manifold for the usdm one, its a 97-2001 manifold and this one has a breather in the back of it, to what vacuum that one goes to? if i block it the engine acts like if its going to turn off. the book says that it goes to the iab sensor but im running the engine with a tuned p28.i don't think is going to read it.oh and what kind of suspention should i use for this accord wagon,i put new gr-2 shocks on it with tein springs and the ride suckt bad they blew up quick.
So you need an internal coil distributor cap.
I'm not 100% if it will fit but the 92 Prelude SI VTEC (H22A1) Honda part number 30102-PT3-A12 is an internal coil (4 wire) H series distributor.
