Suspension & Brakes Theory, alignment, spring rates....
Will it really work!!
Old Aug 24, 2010 | 03:07 PM
kasperwhoo's Avatar
Default Will it really work!!
All on ITR Suspenion!
- 94_95 Acura Legend front dual piston calipers
- 00 Honda CRV front rotors and pads
- 03 Acura RSX rear calipers
- 05 Honda Civic SI rotors and pads
:s cared::sca red:
Old Aug 24, 2010 | 04:37 PM
roastbeefrichie's Avatar
Default FRONTS
yes, it will work
https://honda-tech.com/forums/suspension-brakes-54/caliper-bracket-interchangability-2677539/
the legend GS 2-pots will work on your ITR 5-lug front knuckles. nsx & ITR single pot (stamped 17CL15VN) will work as well on this set-up. you'll need to examine the brackets which are on the caliper (they're stamped 23T, 25T or 28T). ideally, you'll want the 23T, which is meant for a 23mm rotor (ITR specs 23mm 11" front rotor).
i'm not 100% sure about the 00 honda CRV front rotors,
if you're staying with 23T brackets, then i recommend oem ITR rotors or prelude VTEC 11" rotors
use of NSX brackets (stamped 28T) w/ NSX calipers
Originally Posted by migs, "NSX Caliper Install + Legend GS 28mm rotors"
https://honda-tech.com/forums/acura-integra-type-r-8/finally-nsx-brake-caliper-install-legend-gs-rotors-239844/
link to NSX calipers on an ITR, but also pertains to legend GS 2-pot & ITR single-pot
https://honda-tech.com/forums/acura-integra-type-r-8/question-regarding-nsx-calipers-itr-1159478/
Default FRONT PADS
1997-2002 Acura CL V6,
97-01 Acura Integra Type R,
91-95 Acura Legend,
91-02 Acura NSX,
96-02 Acura RL,
95-98 Acura TL,
92-94 Acura Vigor,
91-99 Honda Accord Wagon,
95-02 Honda Accord Sedan,
98-02 Honda Accord Coupe,
97-98 Honda CRV,
93-01 Honda Prelude VTEC
Old Aug 24, 2010 | 04:44 PM
Default RSX REAR CALIPERS
Originally Posted by roastbeefrichie
itr caliper (stamped 9CLP14S) use a 5-lug 10.2" rear rotor,
shares the same stamping, pad & rotor size as ep3/rsx rear calipers;
but the caliper bodies are different (itr vs ep3/rsx).
90-01 integra LS/RS/GS/GSR rear caliper (stamped 7clp13s) uses a 9.4" rear rotor 4X100
the 9CLP14S itr/ep3/rsx rear calipers uses a bigger piston & bigger pads
than the integra 7CLP13S rear caliper
the 03 RSX calipers will work, but they must be mounted left-side right & right-side left. you'll also need to bleed the calipers unmounted (or inverted) since the bleeders are pointed the wrong way
https://honda-tech.com/forums/suspension-brakes-54/dc2-itr-rear-calipers-vs-non-itr-integra-rear-calipers-2759665/
Old Aug 24, 2010 | 04:47 PM
Default REAR 10.2" REAR ROTORS
04-05 EP3 civic Si
02-06 all RSX
Integra Type-R
are all 5 lug, & use 10.2" rear rotors
Old Aug 24, 2010 | 04:56 PM
Default REAR PADS
not sure about the 06 civic Si's specs...maybe someone can chime in & confirm specs for the rear disc set-up?
the 9CLP14S caliper variants are available in many models (ie., ITR, 97-00 CL, prelude VTEC, RSX, 01-05 EP3 hb civic Si, etc), they all share the same sized pads.
i've found that going with any EP3/RSX rear pads will save you the trouble of trial-and-error
...and that's your brake set-up
Last edited by roastbeefrichie; Aug 24, 2010 at 07:46 PM. Reason: EP3/RSX REAR PADS
Old Aug 25, 2010 | 06:56 AM
Charlie Moua's Avatar
Default Re: Will it really work!!
haha , it seems that after so many years people still question it.
emaka9
Nov 21, 2008 09:57 AM
BassBoy19
Apr 19, 2004 10:22 AM
B2FiNiTY
Jan 23, 2004 02:10 PM
IN VTEC
Aug 20, 2001 10:21 PM
