Help...plan to service my R
I am nearing 90K miles on my ITR and plan to have it serviced. I was wondering if anybody could help me out and let me know what is all needed (parts wise). These are the things I am having done to my car.
1. Adjust alternator belt
2. Water pump
3. Timing belt/tensioner
4. Valve cover gasket
5. Spark plugs
6. Wires
7. Dist. cap/rotor
8. Cam seals
9. Fr crank seal
10. Drive belts
11. VC gasket set
12. Valve adjustment
13. Brake fluid flush
14. Coolant flush
15. MTF
16. fuel filter
17. set ignition timing/adjust cambelt
18. adjust parking brake
I know most of them are just adjusting and don't need actual parts, but for the ones that do require parts, what is all needed? I am trying to get a list to order the parts online rather than the dealership to save money. Any info is appreciated. Thanks so much.
2. Water pump
5. Spark plugs
6. Wires
7. Dist. cap/rotor
8. Cam seals
9. Fr crank seal
10. Drive belts
11. VC gasket set
14. Coolant flush
15. MTF
16. fuel filter
OffT: if it's possible, have them do it all in one day (you drive there, they do the work, you come back later to pick it up) because i personally wouldnt trust any dealership mechanics to work on our R cuz im pretty sure (80%) that theyre gunna joy ride it. but that's just me.
oxygen sensor, distributor o-ring, shifter bushings, and whatever else you feel necessary from the owner's/Helms manuals. Most of that stuff can be done at home with the specialty tools coming free from Autozone (eg timing light).
Here are a few extra little things that I did @ 90k miles to freshen the car up a lot and makes it feel like a brand new car that just rolled off the dealership lot.
1. New seals around all the corner lenses as moisture was getting into a couple of them.
2. New OEM floor mats and OEM shift **** (I have the red stitch one)
3. New tabs to fix rattling window on passenger side (rattled when shutting car door with window down)
4. New weatherstripping
5. New tires. In my case Bridgestone Potenza RE11's.
6. New green gel battery because my old one froze over winter in storage after my alarm drained it. Yes, I know. I should have unhooked the battery but the car was stored rather hastily.
Next year when it comes out of storage it's going to get a complete OEM bushing treatment and OEM suspension check over / tune up.
Do you have any moisture in your rear tail lights? Those gaskets have gone in a lot of integras I see.
Check your grounds for rust or dirt. Just something you can do yourself with a wire brush or sandpaper to clean them up. Actually makes a difference!
Full 90k tune-up right here-
91213-PR3-004
14400-P72-014
14510-P30-003
14516-PR4-A00
11925-P30-000
11926-PR3-000
11832-P72-000
11831-P72-A00
11812-PJ7-310
31513-SR3-000
13622-PR3-000
90017-PR3-003
11251-P30-004
15825-P08-005
12513-P72-003
12030-P73-000
30102-P72-006
30103-P73-003
30110-PA1-732
30135-P73-004
30107-P73-004
32722-P30-405
38920-P73-013
56992-P72-004
31110-P73-A01
14510-P30-003
19200-P72-013
17130-PM6-G01
15613-PC6-000
76620-SR3-A01
76630-SH3-G11
16010-ST5-E02
50841-ST7-Z00
50842-ST7-Z00
08718-0004
08798-9013
08206-9002A
08798-9031A
94109-20000
94109-14000
15400-PCX-004
94109-14000
90009-PH1-000
4100-0002
08734-0010
08700-9204A
08700-9206A
OL999-9011A
08798-9025A
02 sensor you can get a genuine NGK/NTK or Denso for much cheaper than OEM. Spark plugs, same thing. Get your NGK plugs at local auto store. No reason to buy OEM there either.
Forgot to add the air filter also, don't forget that. I am sure there might be one or two things I am forgetting, but this list gets you started.
91213-PR3-004
14400-P72-014
14510-P30-003
14516-PR4-A00
11925-P30-000
11926-PR3-000
11832-P72-000
11831-P72-A00
11812-PJ7-310
31513-SR3-000
13622-PR3-000
90017-PR3-003
11251-P30-004
15825-P08-005
12513-P72-003
12030-P73-000
30102-P72-006
30103-P73-003
30110-PA1-732
30135-P73-004
30107-P73-004
32722-P30-405
38920-P73-013
56992-P72-004
31110-P73-A01
14510-P30-003
19200-P72-013
17130-PM6-G01
15613-PC6-000
76620-SR3-A01
76630-SH3-G11
16010-ST5-E02
50841-ST7-Z00
50842-ST7-Z00
08718-0004
08798-9013
08206-9002A
08798-9031A
94109-20000
94109-14000
15400-PCX-004
94109-14000
90009-PH1-000
4100-0002
08734-0010
08700-9204A
08700-9206A
OL999-9011A
08798-9025A
http://www.parkacura.com/
parkparts@hotmail.com
I strongly recommend replacing your cooling system hoses at the same time - the two large ones (upper and lower) at a minimum, and maybe all the little ones as well. They probably need it and this is good preventive maintenance. Plus you're already flushing the fluid and creating better access to them when you replace the water pump.
Part numbers:
19501-P73-010 HOSE, WATER (UPPER)
19502-P72-000 HOSE, WATER (LOWER)
You can find dealers with great discounts on parts ordered over the internet in this topic.
Part numbers:
I did a full tune up on my GSR motor and dealer cost for all parts was about $350 to give you an idea. I can honestly say it runs alot smoother then my ITR motor which I havent touched besides doing an oil change.
Don't really see a need to go to the dealer for every part. I've used aftermarket distributors, rotors, wires, fuel filters etc for a while with no problems.
The majour stuff I would stick with a dealer...water pump, timing belt, etc...
irev210...
are alot of those parts even necessary? parts such as the seals (11925-p30-000, 11926-pr3-000, 11832-972-000, 11831-p72-a00) Also the washers, plugs, bolts, and insulators (90017-pr3-003, 30135-p73-004, 50841-st7-z00, 50842-st7-z00, 94109-20000, 94109-14000, 90009-ph1-000). Lastly, there were alot of part numbers that did not show up when i searched for them (08718-0004, 08798-9013, 08206-9002A, 08798-9031A, 4100-0002, 08734-0010, 08700-9204A, 08700-9206A, OL999-9011A, 08798-9025A. Is there anyway you could briefly describe or identify these parts? Thanks so much. I really appreciate it.
I'm thinking I might as well go with OEM, since I plan get majority of my parts through a dealership. But has anyone heard anything about Denso O2 sensors? They are on sale and pretty cheap at sparkplugs.com right now. I've read briefly that they are pretty much OEM, is taht right? http://www.sparkplugs.com/results_app.asp. I will be needing the front and rear, is that correct? And should I be going with the super or regular class? Thanks for all the info people!!
samco is a superior hose to oem, also costs more
denso i thought was the oem o2?
denso/ngk anything is a win with these cars
op, 4 and 11 are the same thing
don;t have much to add, everyone covered it all.
plug wise the ngk iridium 7s are your best bet for a long service life
With the denso o2 sensors should I be going with the super (identical) or regular class (universal)? Is there really that much of a difference. The difference between each set is about $70 on sparkplugs.com. They have a big sale on the super (identical) set which is why I'm asking.
universal means you make your own plug. direct is plug and play. the ngk sensor is around $50 on ebay. the primary o2 should be cheap, its the after cat that's spendy
Does anyone know if these parts are even necessary? parts such as the seals (11925-p30-000, 11926-pr3-000, 11832-972-000, 11831-p72-a00) Also the washers, plugs, bolts, and insulators (90017-pr3-003, 30135-p73-004, 50841-st7-z00, 50842-st7-z00, 94109-20000, 94109-14000, 90009-ph1-000). Am I able to use existing parts or should I purchase new ones as well? Thanks so much to everyone thats given feedback/advice. I appreciate it
lol im gonna repost same question..everybody seems to either not know or is avoiding it..
