D15 i.d.
Old Aug 24, 2010 | 01:48 PM
Ef4doorFTW's Avatar
Default D15 i.d.
I have a 1991 sedan lx and about five months ago i put a d15 in it that I bought from a Japanese import motor store. It s a sohc non vtec dfpi. I lost the paper work and now I'm having trouble figuring out wat d15 I actually have. The stamp were the tranny meets the engine only says d15. Any help with i.d.-ing the exact type of d15 I have would be really helpful.
Thank you for your time
Old Aug 24, 2010 | 06:02 PM
Projekt_Ef9's Avatar
Default Re: D15 i.d.
I have the same motor. It is just a straight D15b no number after. It came in a lot of Dual carb civics in japan.
Old Aug 24, 2010 | 06:07 PM
Most of the specs i have ever been able to find on the motor have been innacurate though. Most of them say it has 130hp and that is way off.
Old Aug 24, 2010 | 06:11 PM
This might be farely more accurate though.
D15B
Found in:
1988 Honda CRX 1.5X (rare)
1990 Honda Civic 25XXT Formula (Japanese Market)
Honda Civic Ferio MX (Japanese Market)
1998-2001 Honda Capa GA4 (Japanese Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 × 84.5 mm (3.0 × 3.33 in)
Compression : 9.2:1
Power : 105 ps (77.23 kw) / 6400 rpm
Torque : 98 ft/lb / 4500 rpm
Rev limiter : ??? rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : Dual Carburetor/fuel injected
Old Aug 24, 2010 | 06:41 PM
h23abb6's Avatar
stop wasting ur time and money on those weak *** motors...i mean they are super reliable but not worth the effort to do anything with them than just to keep them stock...buy a dual cam and call it a day..
Old Aug 24, 2010 | 07:05 PM
that is generally the idea to get a dual cam but mine came with that motor but i have seen sohc junkyard builds making more than dohc power and still being na.
Old Aug 24, 2010 | 08:54 PM
mattliston's Avatar
for the douchebag above
a 130hp D15B mpfi motor toasts your avereage dual cam b16, and with boltons beats a b18
engine efficiency is a miracle of retards not paying attention to it
Old Aug 24, 2010 | 11:13 PM
Ef4doorFTW's Avatar
Wow really??? Thanks for the info.
@H23abb6... Calm down bud
Old Aug 24, 2010 | 11:38 PM
DCRB's Avatar
if your user id is what you own, then gtf out of the ef forum you troll.
o/p, the motor you have is the same as a d15b1/b2/b7 mechanically. so belts, hoses, water pump, alternator, etc. is the same as the stock motor that was in your car before hand.
Old Aug 25, 2010 | 07:59 AM
h23abb6's Avatar
listen guys im not trying to rag on ur ****...and yes i do have a bb6 prelude with an h23a vtec but thats not the point...i used to drive a 95 civic d16z6 and man i loved that car b4 it was stolen...im jus sayin that from a performance stand poit a dual cam vtec or non vtec will have slightly more torque which is deff usable in a crx...which btw i love crx's...and im not a douchbag im a cool guy...i love all hondas and all their engine offerings....sorry if i offended some of u...just trying to shed some light to u guys..
Old Aug 25, 2010 | 08:28 AM
mattliston's Avatar
if you love all hondas and all the motor offerigs
STFU about swapping
the crx doesnt need torque, its light as hell and goes fast with any motor in it
Old Aug 25, 2010 | 08:41 AM
julioboostamante's Avatar
STFU about swapping
Light or not, Torque is something worth having. Rather have some than none. And your statement about it going fast with any motor is a bit much. I cant imagine it being very fast with a d15b in it vs a d16z6, Y8 or anything bigger than that.
NO need to apologize, some people are just easily offended. Kudos to you for trying to clarify your intentions.
Old Aug 25, 2010 | 09:03 AM
TJChad's Avatar
so wait.......people think that a stock D15 has 130 hp?
Old Aug 25, 2010 | 09:22 AM
mattliston's Avatar
the JDM d15b has 130hp and dusts d16y8s like they were standing still
I pulled a 14.8 on an internally stock d15b2. had a different cam and was of course switched to MPFI so I could convert to OBD1 chipped p06
spent like 100 bucks overall
much better then stock 16.4 or something
Old Aug 25, 2010 | 09:45 AM
TJChad's Avatar
ok
Old Aug 25, 2010 | 09:47 AM
14.8 on a stock single cam seems a bit of an exaggeration. mid 15's to high 15's maybe but high 14's is a bit far fetched to me. Not calling you a liar but you give the impression that anyone can run those ET's with that set up. Maybe in a completely gutted CRX with no hood, doors, no trunk and no driver. But then you'd have to rig it like the delorean In Back to the Future
Old Aug 25, 2010 | 10:40 AM
Ef4doorFTW's Avatar
Thanks for all the info guys. Since it's my daily driver, I think I'm just gonna do the mpfi swap and call it a day, maybe a mini me swap in the future
thanks again!
Old Aug 25, 2010 | 03:07 PM
DCRB's Avatar
apology accepted
i will say this, that b series torque is nice...
Old Aug 25, 2010 | 03:45 PM
that jdm d15b that has 130hp also has vtec
JDMKID206
Acura NSX
Dec 21, 2007 05:53 AM
Blindstuff
May 13, 2004 08:58 AM
W.O.P.
Mar 16, 2004 02:42 PM
300zxTT
Jun 19, 2003 02:17 PM
DOHC_SiDe
Jan 20, 2002 11:32 AM
