any one ever have this happen? aeromotive filter
Old Aug 24, 2010 | 01:15 PM
h22 civic's Avatar
Default any one ever have this happen? aeromotive filter
car was idling like shiz so after a few checked things i ran into this wtf,,,,the end cap came off and was blocking fuel into the fuel rail i got lucky
Old Aug 24, 2010 | 01:25 PM
PuroMotor's Avatar
Default Re: any one ever have this happen? aeromotive filter
Wow lucky indeed.
Old Aug 24, 2010 | 03:14 PM
underpressure02's Avatar
Yes the same thing happened to my aeromotive filter. It was a smaller filter on my daily driver. The car was tuned that way and then when I went to change it I noticed the filter was messed up. I changed the filter and my car was running pig rich.
Garage 808 Hatch's Avatar
Have installed backwards? Fuel should flow towards that cap keeping the filter pressed on it's collar.
Old Aug 24, 2010 | 04:47 PM
h22 civic's Avatar
theirs only 1 way to install it
Old Aug 24, 2010 | 04:59 PM
HamiltonRex's Avatar
I way to install the filter into the housing, but did you install the actual housing in the right direction? Like the housing should be marked in/out.
Old Aug 24, 2010 | 05:05 PM
h22 civic's Avatar
yes their are arrows on everything ive had it on this car for 8 years
Old Aug 24, 2010 | 06:14 PM
Enzo-Racing's Avatar
Doesn't surprise me.. I don't use anything made by aeromotive.. It's all junk...
Old Aug 24, 2010 | 06:38 PM
Honda1949's Avatar
So...Who makes a good filter
Old Aug 24, 2010 | 07:06 PM
miller's Avatar
kinsler!!
Old Aug 24, 2010 | 08:27 PM
em_at_kfi's Avatar
Eh, in aeromotives defense, 8 years is a decent lifespan. You should change elements every 2-3 years at least.
Old Aug 25, 2010 | 04:51 AM
SPOOLINmatt's Avatar
theres nothing wrong with aeromotive for ****s sake, ask a **** ton of people including me that have used their **** for several years.
Old Aug 25, 2010 | 05:41 PM
I.C.C.'s Avatar
I've had great luck with Magnafuel... Always heard mixed reviews on the Aeromotives so just stayed away...
Old Aug 25, 2010 | 05:55 PM
h22 civic's Avatar
lol..im not saying the replacement filter is 8 years old im saying ive been using the filter on this car for 8 years in other words i think i know wich way it is to be installed......the sad part about this is aeromotive **** is made in the usa ....(or supposed to be ))
Old Aug 25, 2010 | 05:57 PM
hello1320's Avatar
First off ......why are you running the paper filter. Get the stainless one
Old Aug 25, 2010 | 06:08 PM
h22 civic's Avatar
they dont make a 10 micron stainless........but i already got a replacement
Old Aug 25, 2010 | 07:50 PM
Why would you use a 10 micron?
Old Aug 26, 2010 | 02:53 AM
h22 civic's Avatar
That's what aeromotive told me to use. 100 in the back 10 in the front never had a prob with it until now.....out of curiosity why wouldn't I
Old Aug 26, 2010 | 03:56 AM
I don't like restricting flow.
Old Aug 26, 2010 | 05:10 AM
em_at_kfi's Avatar
Unless you're running your pump at it's absolute pressure limit and/or you need every last drop of fuel it can flow at that pressure (which would be recipe for disaster in the first place), a 2 or 3 psi pressure drop through a proper filter will not present any fuel delivery issues.
Pressure drop on the pressure side of the pump = pump compensates by doing extra 'work' (OK)
Pressure drop on the suction side of the pump = cavitation (not OK)
Old Aug 26, 2010 | 05:48 AM
I agree Scott but our thirsty rotarys run castor oil in our fuel and that **** clogs up everything. Lol.
I filter my fuel before I put it in my tank.
Old Aug 26, 2010 | 06:31 AM
tony1's Avatar
Maybe rotaries are different, but I don't think the word on the street should be 'don't run filters, they restrict flow'. lol
Everyone is doing themselves a favor by running proper filters in the system. If the restriction a filter causes results in you running out of fuel pump, your pump is too small.
Old Aug 26, 2010 | 06:38 AM
Turbo-charged's Avatar
sounds like "i kept blowing the fuse, so i removed it from the system" i knew a kid that said that back when we were like 16 talking about the fuse for his sub amp haha
Old Aug 26, 2010 | 06:55 AM
I made 40hp by removing my filters. Lol j/k
No I wouldn't recommend removing filters for everybody.
I just don't run 10 micron. I use 100
Although alot of cars I tune don't have any filters at all including in their injectors
Old Aug 26, 2010 | 06:58 AM
tony1's Avatar
Sounds like you should educate your customers then. lol
Doesn't take much **** at all to cause injector problems...
