Key stuck in ignition
Old Aug 24, 2010 | 12:04 PM
jcivic96's Avatar
Default Key stuck in ignition
My key keeps getting stuck in the ignition after I shut the car off? Anyone have any thoughts what the problem could be??
Old Aug 24, 2010 | 12:38 PM
joe_accord23's Avatar
Default Re: Key stuck in ignition
push key in and turn counter clockwise.
Old Aug 24, 2010 | 12:48 PM
TheMuffinMan's Avatar
He knows where you live!
Kind of an *** remark....
The steering wheel if locked can prevent the key from moving, try jiggling the steering wheel while doing it. Alternatively if you are cocking the steering wheel til it locks before removing the key it can cause issues.
Old Aug 24, 2010 | 12:49 PM
singlecamslamed's Avatar
Stage 3 CLINGER!
My old 94 Accord used to do this. VERY irritating. I ended up just getting a new ignition. Fixed the problem.
Old Aug 24, 2010 | 12:56 PM
oh no i didnt mean this in a bad way, u see, when i bought my first honda, i couldnt get the key out, called the friend who sold it to me and told me this. there is also that steering wheel technique u mentioned.
Old Aug 24, 2010 | 02:01 PM
slamstrom's Avatar
Is the stuck key an OEM key or an after market key? Is this the first time using this key? Some non-OEM keys may not index correctly (it happened to me). The key body is not far enough away from the first notch on the key, and I was not able to push the key in far enough to disengage from the ignition lock. I had to use a dremel to cut a chamfer on the key body (by the shank). This allow me to push the key in further to disengage from the ignition. Good luck.
Old Aug 24, 2010 | 03:29 PM
45js45's Avatar
is the key out?
Old Aug 24, 2010 | 03:34 PM
Haha, it's all good.
I took it as "Just turn it idiot"
Old Aug 24, 2010 | 04:33 PM
jcivic96's Avatar
The key is able to turn just when I try to remove it it get stuck...I comes out after a few minutes of moving it around. The is stock with the remote on it and it also happens when I use the valet key. I just found out though that there is a recall on it so that good to know
jackl04
Oct 5, 2021 03:09 PM
maryk2121
Jun 25, 2013 11:35 AM
ahloung
Mar 5, 2006 01:34 PM
dc2go
May 23, 2005 10:33 AM
XplodeTeg
Oct 26, 2004 03:52 PM
