Bolts question..started and clutch housing bolts
Old Aug 24, 2010 | 09:13 AM
SIRIUS VTEC's Avatar
Default Bolts question..started and clutch housing bolts
I've got my tranny back on to the motor but im a lil curious about the bolts and i wanna make sure i used the correct bolts before i torque them.
d16Y8 MOTOR
I am speaking of the bolts that bolt the transmission to the motor just so you know.
1.Are all the bolts identical shape and length, with the exception of the starter bolt?
i ask because i have about 5-6 of these bolts that all look the same and there only seems to be 4 bolts needed on the outter case and one that goes behind from the motor to the tranny.
2. There's two bolts to the starter...one long one and one short one. Which one goes on top and which one goes on the bottom of the starter?
Thanks in advance. I just wanna make sure i get this right.
Old Aug 24, 2010 | 09:54 AM
Default Re: Bolts question..started and clutch housing bolts
Its ok guys i figured it all out...
ANyone know the TORQUE ft lbs for the Transmission mounting bolts?
Old Aug 24, 2010 | 10:47 AM
Ok i figured it out, i just turned until i stripped all the bolts, thanks H-T.
Old Aug 24, 2010 | 10:49 AM
haha im just messin..it's 50 ft lbs i believe. i read it here.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/%5Bfaq%5D-d-series-torque-specs-everyone-1169414/
20CiviC02Si
Mar 30, 2015 08:03 PM
dkrex001
Oct 15, 2008 06:24 AM
