93 del sol s to si rear brake conversion
Old Aug 24, 2010 | 01:34 AM
del fast slo's Avatar
Default 93 del sol s to si rear brake conversion
i have been searching around but have found no definitive answer on what i need but,
there is a del sol (what i think to be si) that has disc rear brakes and i was wondering what all do i need for a conversion?
would i need the whole rear suspension, ebrake cables, lines, and bmc?
or
would i just need the spindles, calipers, and rotors?
Thanks
Old Aug 24, 2010 | 02:13 AM
devarian's Avatar
Default Re: 93 del sol s to si rear brake conversion
i just did a complete swap. you dont need it all, but it would make it easier. you will need the brake cable. also you dont need the BMC, but i would get it, and the prop valve
Old Aug 24, 2010 | 08:48 AM
so i can just take the spindles, calipers, rotors, and ebrake cable and be fine for a while?
Old Aug 24, 2010 | 12:23 PM
dpetro1's Avatar
the 93 s and si use the same master cylinder so no need to swap it.
crabb8
Mar 22, 2017 09:13 AM
wstmsol
Suspension & Brakes
Dec 19, 2011 08:43 PM
delfast
10
Feb 22, 2009 07:20 AM
hondabibi
Aug 16, 2004 01:17 PM
Knight2000
Oct 5, 2002 12:18 PM
