vtec, non vtec?
Old Aug 23, 2010 | 09:39 PM
pigvwj's Avatar
Default vtec, non vtec?
so im building a mini me y8. A friend tells me to use a non vtec obd1 distributor on my y8 vtec head. It just doesnt sound right to me, what should be done here?
Old Aug 23, 2010 | 11:27 PM
mattliston's Avatar
Default Re: vtec, non vtec?
hes telling you the truth
d15b7=nonvtec and its distributor will work
the vtec d16z6 distributor will NOT fit
Old Aug 24, 2010 | 01:01 AM
DCRB's Avatar
uhhhhhh you're using a y8 head soooooooo... use a y8 distributor. it communicates just fine with a p28
Old Aug 24, 2010 | 01:42 AM
Redline130's Avatar
What ecu will you be using?
Old Aug 24, 2010 | 07:58 AM
pigvwj's Avatar
i have the p28 installed. So mattliston, your suggesting a d15b7 non vtec dizzy? is there any resource to back your info up? i just wanna make sure so i dont mess anything up and waste money on a dizzy that wont work.
Old Aug 24, 2010 | 08:26 AM
mattliston's Avatar
so does the d15b7 disty
the d15b7 and d16y8 distributors have super close mounting. its why they work
the z6 mounting part of the distributor needs to be "modified" which is a terrible idea
plus the obd1 connector works with obd1 harness's
obd2 y8 disty will have to be wired in, F that
Old Aug 24, 2010 | 09:50 AM
DCRB's Avatar
So your saying you'd rather "make something work" rather then spend the five minutes it takes to depin the two plugs on the stock harness and repin the single obd2 plug so you can use the correct distibutor for that set up? Hmmmmm interesting.
O/p, yes, the d15b7 has the same mounting points as the y8 dizzy, however I don't know if it will work 100% as it was not used on a vtec motor. I would use the y8 dizzy, if nothing else, to ruel out possibility of a problem later down the road
Old Aug 24, 2010 | 09:56 AM
mattliston's Avatar
VTEC has NOTHING to do with distributor wiring
WTF
first match a disty that bolts in
then match teh disty with the OBD number
nothing else matters.
all obd0,1, and 2 honda sohc distributors have teh exact same sensors and wiring inside. mounting, and plug orientation are the only differences across them
Old Aug 24, 2010 | 09:58 AM
pigvwj's Avatar
THANKS MATTLISTON!
Old Aug 24, 2010 | 06:44 PM
spooneg8's Avatar
b7 dizzy WILL work has been done alot and ive done it myself it will work fine
EDITED: matt pretty much nailed it
Old Aug 24, 2010 | 07:48 PM
pigvwj's Avatar
DCRB thanks for your help but you got TOLD! haha.. btw, my car will crank but it wont start. there's no fuel running through the right side fuel hoes, which is a single one. it cranks tho. but how do you get fuel running through there?
there is two air vacuum hoes on the intake manifold, one one the back sensor pointing literally down and the other one is on the right side of the intake manifold thats pointing up on my PMG-FI manifold. anyone know where they're located?
the other one is behind the manifold on the sonsor pointed down.
Old Aug 24, 2010 | 07:58 PM
EatMyVTEC :]'s Avatar
You got owned by listening to a idiot and not DCRB.
Old Jul 8, 2012 | 10:14 PM
chopperkiller's Avatar
what did u do to get it to work? i'm facing the same problems
Old Jul 9, 2012 | 02:07 PM
91turbosohc's Avatar
just get a y8 dizzy if your not sure about the others.
Old Jul 9, 2012 | 02:53 PM
I already got the car wired for obd1. I now have the original dx obd0 dizzy, the z6 dizzy that didn't bolt up correctly and i recently got the 95 dx dizzy that bolts up fine and is obd1. It now cranks but wont start.
Old Jul 12, 2012 | 10:08 PM
Any suggestions?????????????
Old Jul 12, 2012 | 10:31 PM
88LsRex's Avatar
Fuel?
Spark?
Old Jul 14, 2012 | 08:29 PM
it now stays running but it sounds like crap when it idles. the engine mounts shakes like crazy when it idles
Old Jul 14, 2012 | 11:07 PM
Canadian_EF's Avatar
WTF
Actually the "snail tail" inside the distributor is 180* out.
You'll stutter on acceleration and constantly throw code 9 with no solution... How would I know? I dealt with this issue.
Would have never had to deal with it if I didn't listen to "smart people" like this dude.
Old Jul 15, 2012 | 01:17 PM
how u fix that problem?
Old Jul 15, 2012 | 03:16 PM
obd2 vtec distributor (d16y7 or d16y8)
either repin it for an obd1 plug, or put an obd2 plug on your engine harness.
verify your wiring as well.
Old Jul 16, 2012 | 11:10 PM
thanks man. i gotta go order that dizzy and try it.
Old Jul 18, 2012 | 09:28 PM
hey bro, did you have any other problems with your swap like iacv?
Old Jul 23, 2012 | 10:48 AM
bump!
Old Jul 23, 2012 | 11:43 AM
4drEF's Avatar
Keyboard Humorist
