CB7 H22A SWAP MAP SENSOR WIRING HELP
Old Aug 23, 2010 | 07:31 PM
brian8702's Avatar
Default CB7 H22A SWAP MAP SENSOR WIRING HELP
ok i did the h22a swap in my cb7
i pulled the engine out of a smashed cb7. they last owners just had the old map sensor on the firewall.
well i want to use the map on the intake and im a bit confused on the wiring for the map sensor.
since the last owners has it hooked up on the firewall. it didnt have the connecter on the intake.
i got a plug from a junkyard but the wire colors arent correct.
here's a few pics of the wiring i have on my engine. if you guys could ell me what wire goes to where that would be great
here's some pics
wires on intake 1 2 3
green RED YELLOW
WIRES BEFORE STOCK MAP SENSOR BLUE-WHITE STRIPE , RED-WHITE STRIPE , WHITE/BLUE STRIPE
Old Aug 23, 2010 | 08:21 PM
phootbag's Avatar
Default Re: CB7 H22A SWAP MAP SENSOR WIRING HELP
One is a 5volt reference. One is a ground. One is sensor feedback. Shouldn't be too hard to figure out.
Old Aug 23, 2010 | 08:54 PM
GhostAccord's Avatar
Sensor connector GRN/WHT wire = 5v Positive (+) (sensor reference voltage ECU Pin D19) connect to your WHT/BLU wire.
Sensor connector RED/BLU wire = Sensor Ground (-) (ECU pin SG1 D21) connect to your BLU/WHT wire.
Sensor connector YEL/WHT wire = Sensor signal (+) (0.4v - 4.5,5v ECU pin D17) Connect to your RED/WHT wire.
Old Aug 23, 2010 | 09:01 PM
brian8702's Avatar
THANKS ALOT!!!
Old Apr 6, 2014 | 05:51 PM
SQ is the SQUAD's Avatar
@Ghost Accord, do you know if the voltages are different between the older firewall mounted map sensors and the newer throttle body mounted ones?
Old Apr 6, 2014 | 09:33 PM
holmesnmanny's Avatar
they are the same
SoFresh1189
May 26, 2010 09:48 AM
Robs_B18c
Nov 4, 2009 08:39 AM
97EKCRVtec
Aug 18, 2009 11:36 AM
PINKS
Jul 11, 2006 11:57 AM
SpoolinEK
Jan 21, 2004 03:47 PM
