need new o2 sensor HELP!!!
ok so i need a new o2 sensor but i got some questions..
which sensor is best for me? oem? NGK?
and would i get the sensor for an integra gsr (swap), or for a 94 eg (chassis)
thanks..im confused haha
Denso or NGK and you should get the one that fits your current wire harness.
FYI, Narrow band PHO2 sensors for Honda engines operate the same, the differences are in the connectors, number of wires and the lead wire lengths. So as long as it has the right amount of wires, it's wires are long enough and it connects to your harness. Your good to go!
alright thanks.
but im not really sure how many wires i need.
would this be fine
http://ngk.com/results_app.asp
would this be fine
As long as you get the O2 sensor that fits your wire harness you will be good.
Your link doesn't lead to an item, it takes you to a search page.
since your CX came with a 1-wire sensor (in the exhaust mani), don't get one to match the car. You need a 4-wire replacement. I would think any b-series o2 would work since they have the sensor in the header (like you probably have now)
they are really expensive straight from honda.
i would go with:
denso (part# 234-4011)- $50 at Amazon
http://www.amazon.com/Denso-234-4011...2764055&sr=8-1
ntk (part# 24169) - $60 at Summit Racing
http://www.summitracing.com/parts/NGK-24169/
i would go with:
