NY 95 sc d15b hatch fs/ft harvard blue
I dont now if i realy want to sell my car its more of a testing waters type of deal. I have owned this car for 6 years and it was bought completly stock from the original owner. I have alot of time and money in this car and would hate to see it go. I have never wrote an add like this so be kind if its set up all fkd up.
MOTOR:
the motor is a d15b from japan star with about 50k on it. Timing belt and water pump were done at install. the tranny is an ex that has been rebuilt with all new bearings from honda. internaly the tranny was mint. it was one of the cleanest swaps i have personaly seen. doesnt burn/leak a drop of oil! it has a jakson supercharger installed with a 6lb pully. stock z6 header to a skunk 2 test pipe into an apexi ws2. included will be an aem uego that hasent been installed. exedy stage 1 clutch.
SUSPENTION:
the suspention is a gc koni setup. rides mint!!! almost all the bushings in the car have been replaced with es bushings including the rear trailing arms. password jdm 3point front and 4 point rear tie bars. asr subframe suport with asr rear sway hooked to blox lower control arms. all ordered in blue.
INTERIOR:
nothing too crazy just some em1 si seats and and an optional audio consol with a clairion nx409 head unit. the unit has gps and all that good stuff. armrest and ex cluster. skunk 2 shifter and ****.
EXTERIOR:
this is where this car can use some work. the front end probably need a new rad support. idk im not a body guy. there is a little bit of rust on the pass wheel well nothing too bad tho. i have jdm headlights marker lights and tail lights to go with it. as well as new password jdm fenders, oem new bumper, new hood, and new in honda box jdm thin side moldings. i have all new gaskets from honda for the rear tail lights. also jdm fogs with harness and switch. new paint and a little bit of body work and this car would be mint. the underside of this car is absolutly mint and i think i have literly turned every bolt on it. the car is sitting on mint si rims with brand new dunlop tires. tires were almost 400$
in conclusion the car is a great car and mooves out good. i think i just might want something else. im open too all trade as long as its newer than a 92. im also open to all offers just dont lowball me. i know what i have in it and if i dont get the right price ill just keep it like i have for the past 6 years. i have receipts for almost all of the major purchases. if your car is worth more i have money i can put on top. lmk what you have. most likely i wont trade for anything that i dont have to put money on top. just trying to upgrade i guess. this car nvr gets driven as i have a daily. maybe 500 miles since supercharged it just sits in a garage. you can call/txt netime at 845-416-7590
MOTOR:
SUSPENTION:
INTERIOR:
EXTERIOR:
MilanVTEC
Aug 26, 2001 09:42 AM
