Belt tensioner fail cams rotated 180degrees! helP!
Old Aug 23, 2010 | 08:26 AM
Jdm_driver4's Avatar
Default Belt tensioner fail cams rotated 180degrees! helP!
Ok so i started my motor after TDC. The engine ran for a few seconds then shutoff. I started it again tried to keep it alive with the throttle, it worked. Then let off the gas and the motor turned off. When i looked at the cam gears after TDC the crank, the cams rotated 180 degrees!!!! up arrow facing down. The belt was also shaking violently. The belt tensioner wasn't torqued down enough............. what do i do?! New Head? New Valves? Its a B20b non-vtec.
wunfstgsr
45
Nov 26, 2015 10:43 AM
hondachris1994
12
Aug 23, 2008 12:17 PM
slimjimdanny
Apr 19, 2007 05:32 AM
dwn4cause
Jun 20, 2005 09:10 AM
