FS 2008 Honda Ruckus GY6 Swap Stretched Many Mods
Old Aug 23, 2010 | 08:07 AM
RDAYA0's Avatar
Default FS 2008 Honda Ruckus GY6 Swap Stretched Many Mods
Selling my 2008 Honda Ruckus. Need it gone no room to store for the winter!
Engine
-stock GY6 engine swap (fresh motor, i would say under 300 kms. engine is worth about $1500 and the harness is another $300. also need to get a mount)
-11 pole stator
-Mikuni vacuum fuel pump
-BTX drag header and drag exhaust
-Uni foam filter on stock carb
-NGK spark plug and Nology wires
-stainless steel throttle cable
-Achi adjustable CDI
-Achi aluminum intake manifold
Body
-shaved frame of tabs and hinges
-shaved stock tail light
-Pray for Mojo weld on engine mount
-Kijima amber sidemarkers
-Kijima sponge grips
-Dingleberry LED tail light
-Jiangwayne lowered seat
-Password JDM gas cap
-Password JDM kickstand(chopped for a lower lean)
-Password JDM foot pegs
-Cup holder
-behind the tire plate holder
-clear fuel lines
-Koso black side view mirrors
-s2 HYS underseat compartment(i have a first aid kit in there and the manual)
-Stock GY6 rear fender(not installed)
-Stock Ruckus front fender/reverse install(not installed)
Suspension
-custom front(ruckus stem w/gy6 triple tree and forks welded on)
-lowered forks
-custom rear shock mount
-Doppler neumatic rear shock
Wheels/Brakes
-CRG CNC levers w/master cylinder(front disk, rear drum)
-Acewell Speedometer/backlit(semi installed, wired up but haven't installed speed sensor, needs custom mount)
-stainless steel front and rear cables
-GY6 3 spoke rims
Located: Winnipeg, Manitoba
The ruckus runs great, feels like new. Very fast for a stock GY6 you can still mod this to be a beast. The front brake lever needs to be replaced because the master cylinder got damaged, battlescooter.com has levers for about $130USD
Looking to get $3950CAN, Serious buyer will get extras. Willing to ship anywhere in Canada if you pay the shipping, shouldn't be too much this thing is way smaller than a car. Or you can drive out here and pick it up.
Old Aug 23, 2010 | 11:06 AM
RDAYA0's Avatar
Default Re: FS 2008 Honda Ruckus GY6 Swap Stretched Many Mods
Pics of the ruck
4NLINE UNLIMITED
Jun 26, 2012 07:20 AM
crazyhondahead
Northeast (Sales)
May 28, 2012 08:05 AM
melitza03
Mar 24, 2010 10:32 AM
crxcess
17
Aug 18, 2002 07:56 PM
