CRX o2 Sensor Test
I need to test my o2 sensor on my 90 crx w/1.5 dpi engine. I have a digital voltmeter but need to know what to disconnect to create a vacuum leak during the test.
What exactly are you testing it for? just to be sure that it's putting out a signal? Cause to honestly test it you should need a osciliscope to be sure it's putting out a good sine wave. But with a DMM be sure to put in on the min/max setting so you can see your lowest reading as well as your high reading.
I had my car smog tested and it failed for high nox. The o2 sensor looks like its never been changed. The car has 88,000 miles. I have 10 days to retest or lose 40 bucks. If the o2 sensor shows lack of oxygen it will lean out the engine and cause a nox problem. Other causes could be egr and fuel pressure.
No exhaust leaks prior to the cat as far as i can tell. The muffler is starting to crack around the seem. The car runs nicely and never runs over half on temps. Just high nox.
