intake manifold swap
Old Aug 22, 2010 | 08:23 PM
repingjdm's Avatar
Default intake manifold swap
so i was doin a dpfi-mpfi swap and i went 2 the store came back and some one stole my intake manifold that i was going to swap.so now i have to go buy a new one. i can get a d16y7 intake manifold with everything for $20.but there OBD2 MPFI do i have the change all my wiring or can i keep it
OBD-o?. or i can get a d15 intake manifold off a vtec which is OBD1 MPFI for $50. the engine i got is a sohc zc none vtec in my crx dx. i got a turbo for it too that i wanting to install later on.Any help appreciated guys
Old Aug 22, 2010 | 09:11 PM
crx_si-r's Avatar
Default Re: intake manifold swap
They are both mpfi, but are different. I would just get the One off the d15 later on you can upgrade to the 96-00 civic ex manifold. This manifold from what I know is the beefiest stock manifold for a d-series, it's the type r of sohc motors
Old Aug 22, 2010 | 09:35 PM
repingjdm's Avatar
will i have to change my whole wireing for the d15 manifold? or can i keep it obd-0? i just need one that is fast to install because this is my daily driver.i been looking for a
d16a6 manifold but i cant find any in my area
Old Aug 22, 2010 | 09:39 PM
crx_si-r's Avatar
There is no need to change anything. It makes no difference I'd the manifold is obd0, obd1 or obd2. Your manifold has nothing to do with having to change your obd_ set up. Just run your harness like normal and accommodate the appropriate injectors.
Old Aug 26, 2010 | 04:53 PM
repingjdm's Avatar
ok so i got a d16a6 intake manifold for free with everything just missing the injectors. cant find any obd-0 injectors my friend gave me some injectors off a d16y7. he told me they would work. but he told me that i wont need the injectors resistor box? is this true? i dont want to fry them i know the plugs are different on them. and will the
pm6 ecu run them fine or can i use a different ecu? any help appreciated!
Old Aug 26, 2010 | 05:24 PM
D16SiHatch's Avatar
that sucks dude. there are like 2 engines whose injectors you can't use, and one of them is the d16y7. they are 190cc rather than the normal 240cc. if you do find saturated injectors that are the right size though then yes you will need to delete the resistor box. any ecu can run any type of injectors, it only matters that the peak/hold injectors have the box and the saturated ones do not.
Old Aug 26, 2010 | 05:50 PM
repingjdm's Avatar
wow this scks i drove 1 hour and a half to his house to get them . got to wake up and go to all the junk yards and find some ugh. which injectors dont need the resistor box? or which injectors will work trying to get this dpfi to mpfi conversion done lol
Old Aug 26, 2010 | 07:16 PM
D16SiHatch's Avatar
pretty much any b-series or d-series injectors will work besides ones from a d16y7, d15b6, and d15b8. if they are from a pre-92 vehicle then you will need a box, if 92 or after you do not.
Old Aug 26, 2010 | 07:40 PM
repingjdm's Avatar
alright thix man for the help man hope i find some at the junk yard tomarrow
Loyal2amr
Apr 16, 2008 06:45 PM
turbotime
Aug 11, 2006 01:17 PM
airmandad
Jun 16, 2004 05:45 PM
tmacb78
Mar 31, 2004 02:49 PM
