A/C Pulley/Belt Replacement Problem
Old Aug 22, 2010 | 07:21 PM
zx92027xz's Avatar
Default A/C Pulley/Belt Replacement Problem
Hey, I might be doing this entirely wrong, but I need to ask the question...
I am putting the belt back the A/C compressor and I can't figure out how to move (what I assume is) the tensioner pulley down to slide the belt over it.
when I turn the top bolt, it just backs out and doesn't move anything. When I TRY to turn the bolt on the right, it wants to strip... you can see the edges getting rounded.
help, please.
Old Aug 22, 2010 | 07:34 PM
sde780's Avatar
Default Re: A/C Pulley/Belt Replacement Problem
spray the **** out of the bolts with pb blast, use 6-pt socket on bolts that want to strip, I loosened the long 10mm and the one in the middle of the pulley when I did my swap. Think I loosened the one in the middle of the pulley first
Old Aug 22, 2010 | 07:51 PM
Former User's Avatar
Yes, you need to loosen the center nut of the pulley first.
-InteGSR-
Feb 2, 2010 06:39 PM
olracer66
Jul 8, 2008 07:46 PM
borat
Jul 26, 2006 04:38 PM
omeara7
May 3, 2004 09:11 PM
penney
Feb 10, 2004 04:50 AM
