Can someone verify these CEL codes?
Well, my cluster is from some JDM carbed car so it does not have a CEL in the cluster at all. No, it's not just a burnt out bulb...I've shown proof on here that the cluster simply does not have a CEL anywhere and this was verified by DeSchlong to be from a carbed car. Anyhow, I wired a light in to read codes because my car is running rich. I'm unsure of what the codes I'm getting are. I tried a big bulky automotive type light and got codes 20 and 22. At least thats what it appeared to be. I changed to a smaller LED light and I pulled the fuse for the ECU and checked again...I didn't throw any codes after doing that. Drove the car around for a bit and checked for codes. Still showing a code 22 and what I believe is a code 36. This doesnt make sense to me because 36 is traction control for JDM vehicles. I don't have a JDM car, I have a B16A swap with GSR tranny. Included is a video, let me know what you think the codes are that flash. I checked codes 3 times in the vid, just to be sure that it was clear what was happening. To me, neither of these codes should make the car run rich, but maybe I'm reading the codes wrong? I look forward to your answers.
http://www.youtube.com/watch?v=BTF9oNFcSDk
I definately see a 36 in there. JDM ECU? I seem to recall someone having this issue before, JDM P30 from SiR with TCS will throw a code for it IIRC.
No, I'm running a chipped/socketed P06 with Moates Ostrich in place of the chip. Converted for VTEC. Should be P28 Equivalent. Neither one of these codes explain why I'm running rich either. Is it possible that because I'm running P30 B16A basemap in the P06, that I am getting that Code?
Chipped B6
11
Feb 24, 2009 09:25 AM
kevinoneill
Feb 3, 2005 12:05 PM
