D15 smoking out every hole
Old Aug 22, 2010 | 01:53 PM
honda freak 101's Avatar
Default D15 smoking out every hole
anyone have any segestions on this have a d15b8 somke out off crankcase, dipstick tube, and my exhaust smokes so bad i make cars disapear
compression is 4-170 3-175 2-175 1-175 it idles rough my cap was corroded to all hell and rotor was burnt plugs were fauling so replaced plug wires cap and rotor timing is right on the money any segestions??
Old Aug 22, 2010 | 05:37 PM
Green Crack's Avatar
Default Re: D15 smoking out every hole
What color is the smoke?
Old Aug 22, 2010 | 07:46 PM
devney's Avatar
CEL's?
Old Aug 23, 2010 | 04:09 PM
no cel the smoke as went down alot i think it was burning off the coolant in the cylinders but when it somokes it blue so i know its oil but i have lost alot of power im about 90% i have bent valves due to the way it sound the only thing that gets me is how constant my compression is
Old Aug 23, 2010 | 04:36 PM
Have you done a leak down test?
Old Aug 24, 2010 | 01:22 PM
going to this weekend
Old Aug 24, 2010 | 02:13 PM
EJ8_Man's Avatar
Bad Rings?
Old Aug 24, 2010 | 02:24 PM
Originally Posted by EJ8_Man
Bad Rings?
His compression test is all good so it can't be bad rings.
Old Aug 24, 2010 | 02:39 PM
billyinse's Avatar
if compression is good it wont be your valves either....why was there coolant in your cylinders? ...
Old Aug 24, 2010 | 03:43 PM
head gasket was leaking bad
Old Aug 24, 2010 | 06:36 PM
EJ8_Man's Avatar
You can still have good compression with bad rings. My B18C has good compression and bad rings. Leak down test would be a better test then compression
96civicdx2o3
26
Mar 5, 2013 07:18 PM
vipokc
Feb 4, 2009 06:57 AM
JDMtype Eg6
Jul 14, 2007 02:31 AM
boredracer408
Jul 5, 2004 07:29 PM
VNTEC
May 22, 2004 08:23 PM
