K-Series parts
To the dumbasses that stole my Integra... You should have waited another month there would have a been a turbo k24 frankenstein. HA!
Getting out of the honda game.
All blocks and trannies have VINs
I have 3 RSX-S heads that need repair $200 each
K20A2 03 civic SI head good shape $450
RSX-S Crankshaft good shape $200
RSX-S Engine wiring harness $250
RSX-S Water pump housing $40
K24 oil pan $50
K24 dip stick $5
K24 Timing chain cover W/ Crank position sensor $100
K20 RSX-S intake manifold $75
K20 RSX-S Lower plenum W/ injectors $120
K20 RSX-S Short block minor damage to piston 4 its sill intact but it has some small dings $500
K20 exhaust manifold $40
K24 Exhaust manifold $40
K24 Oil pump $50
K20 RSX-S 6Speed Transmission x2 $900 each
K24 long block oil pan to valve cover $400
K20A2 Engine w/intake w/cable throtle w/ injectors w/ coils w/ wiring harness $1700
My number is 713-715-9222
K24 oil pan $50
K24 dip stick $5
K24 Oil pump $50
ALOT of new parts!!! Too many to list so here are the pics
http://s700.photobucket.com/albums/ww7/mark458/
MORE PARTS!
Over 30 different mounts/brackets from d, b, and k series... dont know what all of them are so if you ask me if I have you better send me a pic so I can verify.
98 integra Transmission ECU 28100-P75-A02
99 integra Transmission ECU 28100-P75-A03
96 integra Transmission ECU 28100-P75-A01
91 integra Seat Gelt Warning Control ECU RK-0090
00-01 GSR Egnine ECU 37820-P72-A05
00-01 TL 37820-P8E-A54 2 of them
99 GSR Engine ECU 37820-P72-A02
00-01 RL Engine ECU P5E-A34
3 oil pans from b and k series.
foreverdark
Apr 25, 2009 09:44 AM
1stealthls
Mar 4, 2004 10:52 PM
28100p75ao3, 37820p72804, 37820p8ea54, crankshaft, honda, hydraulic, kseries, manual, parts, pump, rsxs, series, webster
