D15b7 to JDM D15b swap, Help needed!
Hello,
The car is a 1994 Honda Del Sol S 5 Speed. I'm buying a D15b JDM engine and need to know if it will run good through the stock ecu, with the vtec unhooked? My dad is throwing the motor in for me, as I live in Minnesota and the car is down in Florida, which is where he lives. I will swap the ecu and wire the vtec once I get it up here. I really just need to know if the car will run ok without the vtec connected,so he can drive the car up to Minnesota from Florida.Is there anything else I need to do other than changing the ecu and wiring the solenoid for the swap?? Any help you could provide will be greatly appreciated.
Dale
Dale
Thanks for the reply, I read that sometimes you have to mess with the tps, is this common? I'm just trying to figure out any problems my dad may run into.
Dale
Dale
Baller111
Jun 4, 2012 01:06 PM
PurplePill
14
Oct 19, 2004 09:37 PM
