map sensor
Old Aug 22, 2010 | 08:42 AM
mien_civic715's Avatar
Default map sensor
Here my problem i have a 99 civic si with a 94 gsr swap that was converted to obd2. the guy that i bought it from say the car was using the stock b16 wiring harness. the thing is my check engine light is on for my map sensor and i put a new one in and rest the computer and it still on. i got pic of the how they tap in to the original wire harness for the gsr map sensor.
Old Aug 22, 2010 | 11:04 AM
Default Re: map sensor
any help
Old Aug 22, 2010 | 11:11 AM
D16SiHatch's Avatar
the original harness used the connector that is currently connected to the throttle body. the extra plug is there because the previous owner was running a gm 3 bar map sensor. i suspect that the issue is with the area that all the wires are spliced. i would remove the extra connector altogether and make sure there are no crossed wires going to the stock map connector.
Old Aug 22, 2010 | 11:34 AM
yea i just took off the extra plug and i still have a c.e.l. for the map sensor. i dont really know what else to look for
Old Aug 22, 2010 | 12:08 PM
ok i was looking around the ecu area and found a wire that must of came lose so we reconnected the wire and the c.e.l. is gone now
Old Aug 22, 2010 | 12:26 PM
ok now there a check light for the knock sensor. wtf this thing is pissing me off
Old Aug 22, 2010 | 01:36 PM
Eaglekper0046's Avatar
I'd go through and check all the wires. It sounds like a hack together job. Your going to be chasing issues for the next 6 months if you don't.
attica
12
Aug 20, 2009 08:43 AM
0ldsk00lef
Aug 22, 2007 08:55 PM
93dabeast
May 23, 2007 04:24 AM
CRXified
35
Dec 29, 2005 07:49 PM
pnltnc
May 11, 2004 03:43 PM
