DPFI to MPFI swap questions
Old Aug 22, 2010 | 08:39 AM
chafetzk's Avatar
Default DPFI to MPFI swap questions
Alright I have an 88 civic hb base with a d15b1 and **** dpfi. I know someone who has a 90 crx si with a blown engine. Im gonna buy the intake manifold and bracket, injectors, resistor box, throttlebody, distributor, ecu, and wiring harness to do the swap. What ecu do you use in the swap because it does not say in any of the FAQs or searches? Id guess that you use the si ecu because why else would you get it but i just want to make sure.
Old Aug 22, 2010 | 09:05 AM
BiGZ's Avatar
Default Re: DPFI to MPFI swap questions
PM6,Pr4,or PS9 ecu (if staying OBD0) And just modify the DX engine harness,(easily done,run a few extra wires),unless ya feel like swapping entire cabin harness out for the entire si wiring.You CANNOT JUST USE THE Si Engine Harness!!! Search mpfi swap...
Old Aug 22, 2010 | 10:36 AM
chafetzk's Avatar
AlrIght thanks
Old Aug 22, 2010 | 10:39 AM
crvtectim's Avatar
Big Z FTW!
Old Aug 22, 2010 | 11:45 AM
BiGZ's Avatar
Originally Posted by chafetzk
AlrIght thanks
np,you WILL need the dizzy + injector plugs from the si harness for the dpfi 2 mpfi swap. (or dizzy plugs from 89 ish integra same,and any OBD0 injector harness/plugs)
Old Aug 22, 2010 | 02:59 PM
chafetzk's Avatar
Alright cool I should be set then I'll let you know how it goes
Old Aug 24, 2010 | 02:46 PM
JustHonda2's Avatar
would someone that has a dpfi to mpfi harness like to sell it i need one for my zc in a crx swap
dohc_profile
May 31, 2007 11:33 AM
RedEfGoKart
May 27, 2007 12:10 PM
PDRIFT86
Apr 11, 2007 09:20 PM
Racersky
16
Jan 7, 2006 10:50 AM
untitled
Apr 7, 2003 11:18 AM
