cp pistons???
Old Aug 22, 2010 | 06:47 AM
viera's Avatar
Default cp pistons???
i got a set CP's pistons and the part # said is for b16. will they work on any b series if not what s the diff. thanks guys
Old Aug 22, 2010 | 07:21 AM
non-VTEC's Avatar
Default Re: cp pistons???
any B16/B18 yes they will work.
they will NOT work in a B20.
Old Aug 22, 2010 | 07:43 AM
viera's Avatar
ty for the info
Old Aug 23, 2010 | 03:53 AM
91DA-C's Avatar
Any more info on why it'll work, because you'd think they'd use the same part # if it was compatible with B16, B18A/B and B20 instead of having different piston part numbers for each of those type of blocks.
If you look at page 7 from their official catalog http://www.cp-carrillo.com/LinkClick...30%3d&tabid=82 there's 2 codes one for part number SC7000 for a B16A engine, and one for part number SC7005 for B18A1/B1 engines. I imagine for the B20 you can use the LS pistons, but what's the difference between SC7000 and SC7005, even though the numbers listed are the same. If there wasn't a difference there wouldn't be two part numbers.
Old Aug 23, 2010 | 04:43 AM
kyden's Avatar
a b20 is 84mm, an ls is 81mm, hence why they won't interchange. b16 pistons will work in a b16/b18 because its the same bore size, but your compression ratio will vary on head/block setup.
Old Aug 23, 2010 | 06:18 AM
91DA-C's Avatar
They would go in a turbo setup. If I'd use 9:1 compression B16A pistons in a B18A1 block with an LS head will that make my compression much higher than 9:1 where it would defeat the purpose, or should it still be within an acceptable compression ratio for boost.
Old Oct 24, 2010 | 10:48 AM
AznXstazy's Avatar
bump, would like to know the compression ratio it would yield. what i been trying to find it would yield 11.33 : 1 CR
is that correct?
b20vtechatch
Feb 24, 2005 06:47 PM
vti2
Dec 2, 2003 04:28 PM
