vtech head on ef
Old Aug 21, 2010 | 08:27 PM
gnxpro24's Avatar
Default vtech head on ef
will ne vtech head fit ona stock 1.5 civic engine? like the next gen up or nething?
Old Aug 21, 2010 | 08:38 PM
crx_si-r's Avatar
Default Re: vtech head on ef
yes, you can put a quad cam vtec head on your block and be ok.
seriously do some research. im messing with u, in case you couldnt tell. you can put any sohc vtec (NOT "VTECH" BECAUSE IT WHY WOULD YOU WANT TO PUT A PHONE ON YOUR MOTOR?) from 92-00 will work.
Old Aug 21, 2010 | 08:47 PM
D16SiHatch's Avatar
any sohc vtec head from 92-00 will work
more useful info here
http://www.google.com/#hl=en&source=...1c74845306ae3e
edit: damn.. guess i took to long to respond lol
Old Aug 23, 2010 | 06:17 AM
gnxpro24's Avatar
thankx, i wasnt sure because my enigne is a1.5, 92-00 is a 1.6, right now im i the process of taking my engine out to rebuild it(i have another block) the previous owners screwed it, it only has 99,000 miles on the original engine and this is my second time rebuilding it(cuz i didnt put new bearings in it like i should have last time), also i just bought a parts car idnetical to mine except its the later two years of the ef gen. and it came with a five speed so im gonna swap the tranny and the pedals, and then weld the floor piece in for the shifter, possibly evn convert it to crusie control
Old Aug 23, 2010 | 06:27 AM
gnxpro24's Avatar
btw, sorry if these sound like noob questions but, so if i put the vtec head on it will just bolt up and the manifold and everything will be the same? also i heard the 96+ ex had 127 horsepower, so if i put the head on my 1.5 it would have the same...cause if so itd be a hell of a lot less workj then dropping a b18c with 140 hp in
Old Aug 23, 2010 | 06:51 AM
CRX Toad's Avatar
This is called a Mini Me swap. If you look at the FAQ there is a lot of info on this. Also if your able to search I found over 100 threads on exactly what you want to do.
No, it will not yield you 127hp.
UniqueX707
Aug 26, 2012 11:52 AM
JJ's 90 Civic
Aug 1, 2012 11:44 PM
blueaccord90
Feb 10, 2005 08:13 PM
1989_cash_eater
May 18, 2004 08:38 AM
