built b20v swap for sale -mo
this is a complete drop in swap includes all you need to go low 12s or high11s
my best time was 11.99@114 1.7 60ft on 22in m/ts.. ful linterior cx hatch
head- b16, headwork done by steve deandrea @ cccylinderheads website-www.cccylinderheads.com
it has the max flow package(was race package when i got it done), supertech springs retainers and flatfaced valves along with new bronze valve guides
skunk2 pro2 cams and camgears
eldelbrock victorx manifold hondata i/m gasket
pro products 68mm t/b
arp headstuds
3"intake w/blox velocity stack and filter
block-b20z2
rs machine rep itr pistons 84.5 gas ported verticly and hoizotaly
stock rods shot peened w/ arp bolts
honda bearings bottom end balanced
golden eagle oil sandwich/lines for vtec
endyne block breather/catch can
avid solid lowermounts
stock uppermounts filled w/silicone
aem fuel rail
rc 440 injectors
p28ecu w/hondata s200 (has datalog and boost option)
msd 6al ign.. with 2step and rpm selector and msd cap and coil
y21 tranny obx lsd
act 4puck unsprung clutch
act pressure plate
hytech rep bigtube header
axles, shiftlinkage(has energy susp bushings), typer shift ****
tuned by choung at revline
car made 227/151
motor is still in car and if interested ill give you a ride or you can drive if you got cash.
getting back surgury sept 14 so ill try to pull out of car before that. if i dont get to it by then ill pull it when i have a buyer
4600 obo
arp headstuds
block-b20z2
aem fuel rail
rc 440 injectors
y21 tranny obx lsd
act pressure plate
car made 227/151 motor is still in car and if interested ill give you a ride or you can drive if you got cash.
4600 obo
done
Jun 14, 2006 08:34 PM
done
Mar 29, 2006 02:47 PM
cnydelSolHybrid
Jun 25, 2003 02:53 PM
