Parting out 01 integra gsr
Old Aug 20, 2010 | 07:00 PM
nasteboyii's Avatar
Default Parting out 01 integra gsr
First off pics are on my face book page. link here
http://www.facebook.com/album.php?ai...3&l=57bb4b39c7
car was in rolled, pretty much all the pics is all i have left, couple things i didnt take pics of but can if needed
***what is already spoken for ***
***Engine/trans/wiring/ecu./wheels/seats/misc trim pieces***
pretty much everything that survived is up for sale, no reasonable offer refused i dont need the stuff, i dont have integra s
stuff is located in dover delaware, can meet up if close
it was a white integra, black interior,
both front abs sensors w/connectors
abs pump w/about 8inchs of hardline and connector w/4inchs ish
rear abs sensors w/cut connectors (still on disc setup at the moment)
brake master cylinder
brake booster
3 pedal setup (gas, brake clutch) w/all sensors brackets everything needed to bolt into non manual car for conversion (just the pedal assembly)
power steering pump W/brackets if needed (upper bracket sold)
power steering reservior W/ hose
arm rest (fair to not so fair condition)
rear plastic panels, does have one crack towards the top of driver side panel, and one crack on bottom (better then having a really bad condition one i guess)
rear trunk/hatch w/glass and wiper arm
clutch hard line from mid point on fire wall to slave cylinder (just the hard line, also comes with proportional valve or whatever its called)
evap canister w/purge valve
2 front ac hard lines GONE
driver side power mirror assembly
passenger side power mirror assembly
driver side door panel
passenger side door panel
sunroof assembly (still in car) GONE
headliner (still in car) GONE
steering column (still in car)
ignition lock w/key, and door locks
driver side door handle
pass side door handle
driver side upper control arm front
pass side upper control arm front
driver side lower control arm
both front shock forks
rear sway bar w/links and bolts, and brackets
rear bumper GONE
driver side window regulator/motor may be good (still have not removed from broken door)
passenger side window regulator/motor should be good (but still not removed from door)
blower GONE
heater core w/box GONE
a/c core w/box GONE
NEW ADDITIONS
fuse box under hood
fuse box under dash
battery tray and plastic
misc connectors thru out car i cut off
Some aftermarket stuff
Stainless steel brake lines all four corners Russell s i believe 50 bucks FIRM GONE
Ground control with Koni Yellows complete setups (not the junk sleeve style, the complete kit they sell) has upper perch s and all : only problems are, they yellow paint is falling off in alot of places, and passenger side front one bolt missing (was seized to nut, had to cut off. i can put a new one in, and tack in place (basically it s these https://honda-tech.com/forums/wheels-tires-brakes-suspension-48/___-ground-control-koni-yellow-shocks-combos-___-1689953/) I can send pics, just ask i may just put these on one of my other project cars. 550 FIRM sells for 1000
some of this stuff if does not sell before i scrap the shell will go with the shell. if you dont see it on the list i most likely dont have it,
pretty much nothing on this list is worth more than 75 bucks if that. aka make offer.
paypal verified, will only ship to verified addresses
(i will not ship headliner, sunroof, rear trunk/hatch w/glass)
pretty much will ship anything/everything else via UPS w/tracking number
just want to make some money back from this thing. to fund the next project
Thanks
dan
nasteboyii19943@Yahoo.com
or PM here
Old Aug 22, 2010 | 11:27 AM
hpi247's Avatar
Default Re: Parting out 01 integra gsr
any chance you are willing to part with everything needed for a front and rear brake swap to an EG?
Old Aug 22, 2010 | 06:15 PM
nasteboyii's Avatar
u have pm
Old Aug 23, 2010 | 07:00 AM
MilFhunter001's Avatar
Do you have any A/C parts?. I'm looking for the brakets and bolts that hold the lines, the A/C button. Just let me know whatcha got.
Thanks
Old Aug 23, 2010 | 07:23 PM
nasteboyii's Avatar
bump. pm d
Thanks
Old Aug 25, 2010 | 06:54 PM
nasteboyii's Avatar
up for today
Old Aug 27, 2010 | 03:51 AM
nasteboyii's Avatar
bump
Old Aug 27, 2010 | 06:19 AM
fv8s's Avatar
pm me a price on the whole rear disc if you have it. along with MC and booster
Old Aug 27, 2010 | 09:26 AM
nasteboyii's Avatar
u got pm
Old Aug 28, 2010 | 04:40 AM
xtremeness101's Avatar
do you have a rear camber kit or front upper camber kit?
Old Aug 29, 2010 | 06:44 AM
nasteboyii's Avatar
no sir sorry
Old Aug 29, 2010 | 08:41 AM
cvcrcr99's Avatar
This. Thanks!
Old Aug 30, 2010 | 04:49 AM
nasteboyii's Avatar
Originally Posted by cvcrcr99
This. Thanks!
u have pm
Old Aug 31, 2010 | 12:16 PM
nasteboyii's Avatar
bump
Old Sep 3, 2010 | 08:14 AM
nasteboyii's Avatar
bump
Old Sep 3, 2010 | 06:12 PM
nasteboyii's Avatar
more stuff gone, more to go
buy my stuff people
Old Sep 6, 2010 | 04:09 PM
AllMotorDan's Avatar
Still have engine harness? Very interested
Old Sep 6, 2010 | 05:14 PM
nasteboyii's Avatar
yes i still have the engine harness but its not for sale, it stays with the motor swap (unless you want to be whole swap 2500 FIRM)
thanks
dan
Old Sep 7, 2010 | 03:45 AM
Ok thank you, bump so he can get this stuff sold!
Old Sep 7, 2010 | 04:06 AM
94 ls teg's Avatar
pm me a price for the rear bumper
Old Sep 7, 2010 | 04:31 AM
nasteboyii's Avatar
sorry just sold over the weeknd, ill up date post
Old Sep 9, 2010 | 05:00 AM
94CivicSi's Avatar
Did you sell the brakes. I'm in need of a LR caliper.
Old Sep 9, 2010 | 05:49 AM
nasteboyii's Avatar
yes brakes are sold
Old Sep 9, 2010 | 06:21 AM
everythingwentblack's Avatar
No way they are cloth seats that aren't destroyed right? fb link didn't work
Old Sep 9, 2010 | 08:33 AM
nasteboyii's Avatar
as previously posted, seats are not available for this vehicle
sorry
dan
