OH 99 em1 project car SHAVED BAY! BUILT MOTOR
I would really prefer to just sell the project as a whole, but i doubt it will happen. i am losing my house in these hard times, and the project just has to go. i am letting it go only for what i owe on the car itself, and i'm CLEARLY losing my *** on all the money/time invested in the project...I owe $7k. take it ALL how it sits.
99 MR EM1
Brand new 17" rims/tires
APR F1 carbon fiber mirrors
billet motor mounts
FRESHLY shaved bay all seams welded, and headlight holes paneled over and welded
currently the car is gutted, no dash and NOTHING in the bay besides the suspension which is finger tight to roll it onto a trailer, and the rack&pinion
the b16b motor is BULLET PROOF was beeing built for 700whp if you're from Ohio you probably know of Slowmotion motorsports, the motor was build by their old engine builder Scotto who is now a lead tech @ Roush honda...its LEGIT and was being build for his own race car...
the motor ALONE is worth over $7k if you see what alls in it...
Darton MID sleeved B16B block @ 84mm w/ copper o-rings
ERL 5-main girdle w/ arp studs
Scat 95mm Crank
Crower billet rods
CP 9.7:1 pistons
Custom Cometic MLS headgasket
1/2" ARP head studs w/ custom dowel pins
b16 head ported and polished, combustion chanmbers de-schrouded to 84mm
manley inconel exhaust valves
manley stainless steel intake valves
supertech dual coil springs
supertech titanium retainers
Comp stage 4 turbo grind cams
NEW OEM PARTS:
usdm B16 valve cover
oil pan 10an return bung tig welded to pan
oil pickup
oil pump
water pump
timing belt
tensioner
tensioner spring
tensioner bolt
H22 LMAs
camshaft seals
front and rear main seals
sidecover
sidecover gasket
valve cover gasket
oil pump pickup gasket
oil pump o-ring
main and rod bearings
thrust washers
cam gear keyways and bolts
oil pump bolts
water pump bolts
ALSO have polished top mount mani, polished Precision GT35R, NEW port matched Edelbrock IM and hondata IM gasket, Tial BOV, Tial 44mm WG, RC 1000cc injectors, Walbroh 255 pump, GSR trans, Skunk 2 full coils (ride like ****, think their blown), full 3" exhaust, 3" downpipe. car has full interior with an aftermarket steering wheel, i have the OEM wheel and airbag unit still as well...if you're interested TEXT ME, its your best chance of getting ahold of me. #317-408-5206
99 MR EM1
billet motor mounts
Scat 95mm Crank
Crower billet rods
CP 9.7:1 pistons
NEW OEM PARTS:
oil pickup
oil pump
water pump
timing belt
tensioner
tensioner spring
tensioner bolt
H22 LMAs
camshaft seals
sidecover
sidecover gasket
valve cover gasket
oil pump o-ring
thrust washers
oil pump bolts
water pump bolts
here's some more of the stuff that will come with it
TONS OF STUFF...like it says...PLEASE DONT CALL ME, if i dont recognize the number i won't answer. I'm usually working, and i CAN NOT TAKE CALLS AT WORK! if you need to get ahold of me the FASTEST AND EASIEST WAY IS THROUGH TEXT! #317-408-5206
99-00 civic SI steering wheel w/airbag and sensors $200 obo also have pass.side bag w/cover
99-00 civic NOT SI headlamps slight scratches $40
Precision GT35R .82AR w/polished housing $600
MSD 6462 6 series ignition box w/boost timing $200 obo
MSD blaster coil and ignition wires attached to B series Diz $200 obo
APR carbon fiber side mirrors $150
b16 IM w/sensors and fuel rail/regulator $125
innovative 3 piece mount kit black w/red inserts $180
turbo kit w/.82 AR GT35R, intercooler, pipes, 3" downpipe, topmount mani, 1000cc injectors, Tial BOV, Tial 44mm WG (mani will need another flange added to it for clearance) $1800
sorry for the crappy pix
x still jaded x
Aug 23, 2010 01:48 AM
