FS: Fully Built h2b Swap
Im parting my car out and starting with the Swap. The motor was built by Dynamic Preformance in Jersey. Everything is done right, i hate to see it go but now it's time to find something my Kids can ride in... I will sell everything together so you can drop it in a EK with 3" exhaust (if for a coupe)
ONLY THING I DON'T HAVE A HARNESS. I HAD THE RAVELCO INSTALL AND IM NOT MESSIN WITH IT, AND I NOT PAYIN TO DEINSTALL IT
Everything listed below $4,500
With custom 3" bolt on Header back exhaust and muffler $4,850
ENGINE ---
-H22 Port and polish head
-3 angle valve job
-Skunk 2 pro 2 cams
-Skunk 2 pro cam gears
-Supertech springs and retainers
-440 Presion injectors
-Euro R manifold
-Euro R single crank pulley
-H23 tensioner conversion
-Professionl Products 68mm thottle body
-Mahle Pistons 12.5 cr
-Eagle Rods
-AEBS Sleeves
-Custom H2b SSR header
-Evo H2b Kit
-Hondata S300 Ecu
TRANSMISSION
-B16 trans
-obx Lsd
-Itr 4.7 final drive
-comp stage 4 clucth
BLOCK
Exhaust
ENGINE ---
-3 angle valve job
-Skunk 2 pro 2 cams
-Euro R manifold
-Eagle Rods
-AEBS Sleeves
-Evo H2b Kit
-Hondata S300 Ecu
TRANSMISSION
-B16 trans
-obx Lsd
BLOCK
Exhaust
dragpro
Oct 3, 2008 08:02 AM
