couple questions
Old Aug 20, 2010 | 12:15 PM
JJGL-EF90's Avatar
Icon2 couple questions
first my tail lights and center garnesh look so ashy, n my buddys r so glossy n nice, wut can i use that will shine em up, but something that doesnt rub off like wax,
second question is the brake lights dont go on, wat could that problem be?
third question is are there any mounts that will work with swapping a b series in my ed6, i heard DA mounts work? just seeing if there is any alternative besides buying expensive a** mounts hahah
Old Aug 20, 2010 | 12:34 PM
mruneek's Avatar
Default Re: couple questions
i know inavative sells mounts for like 60 - 80 bucks they are steel and poly, vs the 300 dollar hasport.. do some searching
Old Aug 20, 2010 | 05:54 PM
hoga113's Avatar
Get the meguiars plastx or get the meguiars headlight restoration kit and get electric drill.
Old Aug 21, 2010 | 01:01 AM
~sp33~'s Avatar
EFB055
Checked the fuses for your tail lights?
Old Aug 21, 2010 | 05:01 PM
AintIfresh_EF9's Avatar
This works good.....
Old Aug 25, 2010 | 08:59 AM
JJGL-EF90's Avatar
ok koo ill try that out bc my tail lights r ugly
Old Aug 25, 2010 | 09:08 AM
TJChad's Avatar
1- get some sandpaper starting with 800 grit and working down to at least a 2500 grit and "wet sand" your tail lights. Then do a GOOD coat of plastic rubbing compound, then finish with a good plastic wax and you're tail lights will be good as new. The headlight "kit" does work good but doesnt last in the long run and still doesnt work quite as good as the "real" way to fix this
2. Check your fuse and your brake light switch (on your pedal)
3. Hasports are the shiznit but a bit on the pricey side
Old Aug 26, 2010 | 09:10 AM
JJGL-EF90's Avatar
ya that sounds like a more effecient way to shine them up, ok ill check that out, hasports r dope but money is scarce rit now, thanks everybody for the tips, see wut i can do with my next check to get this stuff done
killdevo
Jun 13, 2015 10:12 AM
ekaytrbo
Honda Civic (2006 - 2015)
Sep 26, 2008 03:23 PM
nathchong
May 5, 2007 12:38 PM
jamesc2123
10
Feb 10, 2007 11:56 PM
weak_tec
Mar 21, 2006 04:46 PM
